Hey,
i want to create a type of linked List for a class Control System to Manage a bigger proect. Every Module of this Project has a class as Member and another class get some parameters of this…
My problem is that the data are not correctly saved. i’ve wrote a example script with the same problem but much smaller to post this here… i hope someone can help me… I can’t manage the problem by myself… for me it is a “correct” linked list - but every time the sketch add the new Obj. as firstNode…
class inner {
String name = "n.S";
inner* _nextNode = NULL;
public:
inner(String name)
this->name = name;
inner* getNextNode()
return _nextNode;
void setNextNode(inner* nextNode)
this->_nextNode = nextNode;
String getName()
return name;
class outer {
private:
inner* _firstNode = NULL;
public:
outer(){};
void addInner(String name)
inner newObj(name);
Serial.println("Add Inner");
Serial.print("Name: ");
Serial.println(newObj.getName());
if(_firstNode == NULL)
Serial.println("First Node has no Member");
_firstNode = &newObj;
else
Serial.println("First Node has a Member");
if(_firstNode->getName() != NULL)
Serial.println("Name saved in FirstNode: ");
Serial.println(_firstNode->getName());
else
Serial.println("Object was deleted");
inner* pointer = _firstNode;
int counter = 0;
//set pointer to the last object - this doesn't work
while(pointer->getNextNode() != NULL)
Serial.print("Saved name at Slot: ");
Serial.print(counter + ": ");
Serial.println(pointer->getName());
pointer = pointer->getNextNode();
counter++;
Serial.print("NewNode added at ");
Serial.println(counter);
pointer->setNextNode(&newObj);
void showAllInner()
return;
do {
}while(pointer != NULL);
void getFirst()
Serial.print("Name der ersten Node: ");
outer test;
for(int i = 0; i < 5; i++)
test.addInner(String(i));
Serial.println("fertig");
delay(500);
//test.showAllInner();
test.getFirst();
This is the sketch and the Output:
Add inner
Add Inner
1
NewNode added at 0
Add Inner
2
NewNode added at 0
Add Inner
3
NewNode added at 0
Add Inner
4
NewNode added at 0
fertig
maybe the objects will deleted after the function call? in my other script my esp crash if i want to read out the data… - if someone wants to read the original Code: https://pastebin.com/sAPyuDwS
And the Project (branch: dev_linear_web): GitHub - j54j6/ESPBase at dev_linearWeb
hope that someone can help me ^^ - thanks a lot
j54j6
