I try to upload a code to my target and
platformio run --target upload
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-mklittlefs 1.203.210628 (2.3)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Converting bsesp.ino
TypeError: __init__() got an unexpected keyword argument 'uri':
File "/usr/local/lib/python3.9/dist-packages/platformio/builder/main.py", line 178:
File "/root/.platformio/packages/tool-scons/scons-local-4.2.0/SCons/Script/SConscript.py", line 597:
File "/root/.platformio/packages/tool-scons/scons-local-4.2.0/SCons/Script/SConscript.py", line 285:
File "/root/.platformio/platforms/espressif8266/builder/main.py", line 238:
File "/root/.platformio/packages/tool-scons/scons-local-4.2.0/SCons/Util.py", line 748:
File "/usr/local/lib/python3.9/dist-packages/platformio/builder/tools/platformio.py", line 62:
env.ProcessProjectDeps()
File "/usr/local/lib/python3.9/dist-packages/platformio/builder/tools/platformio.py", line 141:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "/usr/local/lib/python3.9/dist-packages/platformio/builder/tools/piolib.py", line 1089:
project.install_dependencies()
File "/usr/local/lib/python3.9/dist-packages/platformio/builder/tools/piolib.py", line 913:
if lm.get_package(spec):
File "/usr/local/lib/python3.9/dist-packages/platformio/package/manager/base.py", line 236:
for pkg in self.get_installed():
File "/usr/local/lib/python3.9/dist-packages/platformio/package/manager/base.py", line 209:
pkg = PackageItem(pkg_dir)
File "/usr/local/lib/python3.9/dist-packages/platformio/package/meta.py", line 405:
self.metadata = self.load_meta()
File "/usr/local/lib/python3.9/dist-packages/platformio/package/meta.py", line 440:
return PackageMetaData.load(manifest_path)
File "/usr/local/lib/python3.9/dist-packages/platformio/package/meta.py", line 393:
data["spec"] = PackageSpec(**data["spec"])
