I just use a sample code from tinygpsplus but it seems weird? please can somebody help me with this
You are not writing valid .cpp code, you are writing in .ino
style like in the Arduino IDE (or have copied an example from the Arduino IDE which was in an .ino
file).
When you want to call the function displayInfo()
, it must have a function declaration coming before the point of usage. See the FAQ for converting.
In your case, all you have to do is write
void displayInfo();
before the setup function on the global scope.
