I’ve installed the library wolfssl. But now it is installed I cannot include the header files:
src/main.cpp:11:25: fatal error: wolfssl/ssl.h: No such file or directory
What is the problem here? The installation looks good.
Regards!
Regards!
What’s your folder struture of the project (tree
) and your platformio.ini
I’m not sure, what you mean with “structure of the project(tree)”. For my tests, I only used main.cpp under src.
This is the platfomio.ini (I’ve added lib_deps, but with no success):
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
monitor_speed = 9600
wolfssl
Thanks for your help.
What library are you using? I find PlatformIO Registry to be only for mbed-os devices, not the ESP8266.
Also I meant something like
C:\Users\Maxi\Desktop\wolfssltest>tree
├───.pioenvs
│ └───nodemcuv2
│ ├───FrameworkArduino
│ ├───ld
│ └───src
├───.piolibdeps
│ └───wolfSSL_ID2851
│ ├───src
│ ├───wolfcrypt
│ │ └───src
│ └───wolfssl
│ ├───openssl
│ └───wolfcrypt
├───.settings
├───include
├───lib
├───src
└───test
You are right, thats the library I wanted to use. I was not looking at the dependencies, because others are using this lib with ESP. But they do so by using esp-open-rtos.
Thank you for pointing me in the right direction. This question is answered.
