Private library scope?
Just starting out with platformio and have run into an issue. I have a small local library that I use and when I move it into the private lib directory for my project, platformio seems to not find it.
Everything is fine when I put the mylib.h and mylib.cpp files in the main src directory, but once I move it out to lib/mylib/ and update the include to <mylib.h> I get the following error:
'function_from_mylib' was not declared in this scope
The strange thing is I have two other private libraries in lib/ that don’t seem to have the same issue…
See README.txt in lib folder. It has an answer.
I saw that, that’s what I based the existing structure off of, am I maybe missing something?
Here is what my current lib structure looks like:
|--lib
|  |--Base64
|  |  |- Base64.cpp
|  |  |- Base64.h
|  |--NTP
|  |  |- NTP.cpp
|  |  |- NTP.h
|  |--sha256
|  |  |- sha256.cpp
|  |  |- sha256.h
|  |- readme.txt
|- platformio.ini
|--src
   |- main.cpp
And what is inside of main.cpp
#include <Base64.h>
#include <sha256.h>
#include <NTP.h>
The Base64 lib is the one not being picked up for some reason.
Please provide test project to reproduce this issue.
This is a problem of a library that you use. See
https://github.com/agdl/Base64/issues/1
Ha! that was it. I changed the library name and it works. I guess “Base64” might be a reserved word or something?
Did you rename a file or class in library?
I renamed it all. I went from
|--lib
|  |--Base64
|  |  |- Base64.cpp
|  |  |- Base64.h
to
|--lib
|  |--b64
|  |  |- b64.cpp
|  |  |- b64.h
and poof! it worked.
Did you touch library internal code?
Aside from updating the name for the header file in the *.cpp file, no, the code is the same. You can see the diff here: https://github.com/esell/azure_soil_sensor/commit/468ca360cfe07181eae9768ce5e3ed8cd5b6c104
