Just as you did. It is correct that the flag does not show up during the compilation of the .o
object files. It’s a linker flag. It will be included in the very last command.
Check the verbose compilation output of a blinky-example for the Uno with the platformio.ini
[env:uno]
board = uno
-lrf24-bcm
avr-gcc -o .pio\build\uno\FrameworkArduino\wiring_shift.c.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p -DPLATFORMIO=50005 -DARDUINO_AVR_UNO -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO=10808 -IC:\Users\Max\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\Max\.platformio\packages\framework-arduino-avr\variants\standard C:\Users\Max\.platformio\packages\framework-arduino-avr\cores\arduino\wiring_shift.c
avr-gcc-ar rc .pio\build\uno\libFrameworkArduino.a .pio\build\uno\FrameworkArduino\CDC.cpp.o .pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o .pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o .pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o .pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o .pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o .pio\build\uno\FrameworkArduino\IPAddress.cpp.o .pio\build\uno\FrameworkArduino\PluggableUSB.cpp.o .pio\build\uno\FrameworkArduino\Print.cpp.o .pio\build\uno\FrameworkArduino\Stream.cpp.o .pio\build\uno\FrameworkArduino\Tone.cpp.o .pio\build\uno\FrameworkArduino\USBCore.cpp.o
.pio\build\uno\FrameworkArduino\WInterrupts.c.o .pio\build\uno\FrameworkArduino\WMath.cpp.o .pio\build\uno\FrameworkArduino\WString.cpp.o .pio\build\uno\FrameworkArduino\abi.cpp.o .pio\build\uno\FrameworkArduino\hooks.c.o .pio\build\uno\FrameworkArduino\main.cpp.o .pio\build\uno\FrameworkArduino\new.cpp.o .pio\build\uno\FrameworkArduino\wiring.c.o .pio\build\uno\FrameworkArduino\wiring_analog.c.o .pio\build\uno\FrameworkArduino\wiring_digital.c.o .pio\build\uno\FrameworkArduino\wiring_pulse.S.o .pio\build\uno\FrameworkArduino\wiring_pulse.c.o .pio\build\uno\FrameworkArduino\wiring_shift.c.o
avr-gcc-ranlib .pio\build\uno\libFrameworkArduino.a
avr-g++ -o .pio\build\uno\firmware.elf -Os -mmcu=atmega328p -Wl,--gc-sections -flto -fuse-linker-plugin .pio\build\uno\src\main.cpp.o -L.pio\build\uno -Wl,--start-group .pio\build\uno\libFrameworkArduinoVariant.a
.pio\build\uno\libFrameworkArduino.a -lrf24-bcm -lm -Wl,--end-group
As you can see, only the final linker command includes -lrf24-bcm
, which is correct.
If you want to link in precompiled libraries, also don’t forget to add -L path
flag to point to the path where the .a
library is.
