Hi again,
I’m currently trying to program my chipkit uC32 to deal with the Microchip ENC28J60-H (Olimex version of that chip) which is an Ethernet connector managed through the SPI connector of the chipkit.
I used the PmodNIC and DNETcK libraries given here :
When I compile the following code using MPIDE I can generate a UDP server. Anyway, it compiles and it works :
// #include <NetworkShield.h>
#include <PmodNIC.h>
// #include <PmodNIC100.h>
/* Required library, Do NOT comment out */
#include <DNETcK.h>
/* SET THESE VALUES FOR YOUR NETWORK */
IPv4 ipServer = {10,104,11,100};
unsigned short portServer = 44400;
//***************************** END OF CONFIGURATION ***************************************
typedef enum
NONE = 0,
LISTEN,
ISLISTENING,
AVAILABLECLIENT,
ACCEPTCLIENT,
READ,
WRITE,
CLOSE,
EXIT,
DONE
} STATE;
STATE state = LISTEN;
unsigned tStart = 0;
unsigned tWait = 5000;
// remember to give the UDP client a datagram cache
byte rgbUDPClientCache[1024];
UdpClient udpClient(rgbUDPClientCache, sizeof(rgbUDPClientCache));
// remember to give the server a datagram cache that is
// equal or larger than the client datagram cache
const int cPending = 3; // number of clients the server will hold until accepted
byte rgbUDPServerCache[cPending * sizeof(rgbUDPClientCache)];
UdpServer udpServer(rgbUDPServerCache, sizeof(rgbUDPServerCache), cPending);
DNETcK::STATUS status;
// a read buffer
byte rgbRead[1024];
int cbRead = 0;
int count = 0;
/*** void setup()
* Parameters:
* None
* Return Values:
* None
* Description:
* Arduino setup function.
* Initialize the Serial Monitor, and initializes the
* the IP stack for a static IP of ipServer
* No other network addresses are supplied so
* DNS will fail as any name lookup and time servers
* will all fail. But since we are only listening, who cares.
Serial.begin(9600);
Serial.println("UDPEchoServer 1.0");
Serial.println("Digilent, Copyright 2011");
Serial.println("");
// intialize the stack with a static IP
DNETcK::begin(ipServer);
/*** void loop()
* Parameters:
* None
* Return Values:
* None
* Description:
* Arduino loop function.
* We are using the default timeout values for the DNETck and UdpServer class
* which usually is enough time for the UDP functions to complete on their first call.
* This code listens for a connection, then echos any strings that come in
* After about 5 seconds of inactivity, it will drop the connection.
* This is a simple sketch to illistrate a simple UDP Server.
switch(state)
// say to listen on the port
case LISTEN:
if(udpServer.startListening(portServer))
Serial.println("Started Listening");
state = ISLISTENING;
else
state = EXIT;
break;
// not specifically needed, we could go right to AVAILABLECLIENT
// but this is a nice way to print to the serial monitor that we are
// actively listening.
// Remember, this can have non-fatal falures, so check the status
case ISLISTENING:
Serial.print(udpServer.isListening(&status));
if(udpServer.isListening(&status))
Serial.print("Listening on port: ");
Serial.print(portServer, DEC);
Serial.println("");
state = AVAILABLECLIENT;
else if(DNETcK::isStatusAnError(status))
state = EXIT;
break;
// wait for a connection
case AVAILABLECLIENT:
if((count = udpServer.availableClients()) > 0)
Serial.print("Got ");
Serial.print(count, DEC);
Serial.println(" clients pending");
state = ACCEPTCLIENT;
break;
// accept the connection
case ACCEPTCLIENT:
// probably unneeded, but just to make sure we have
// udpClient in the "just constructed" state
udpClient.close();
// accept the client
if(udpServer.acceptClient(&udpClient))
Serial.println("Got a Connection");
state = READ;
tStart = (unsigned) millis();
// this probably won't happen unless the connection is dropped
// if it is, just release our socket and go back to listening
else
state = CLOSE;
break;
// wait fot the read, but if too much time elapses (5 seconds)
// we will just close the udpClient and go back to listening
case READ:
// see if we got anything to read
if((cbRead = udpClient.available()) > 0)
cbRead = cbRead < sizeof(rgbRead) ? cbRead : sizeof(rgbRead);
cbRead = udpClient.readDatagram(rgbRead, cbRead);
Serial.print(cbRead, DEC);
Serial.println(" bytes");
state = WRITE;
// If too much time elapsed between reads, close the connection
else if( (((unsigned) millis()) - tStart) > tWait )
state = CLOSE;
break;
// echo back the string
case WRITE:
Serial.println("Writing datagram: ");
for(int i=0; i < cbRead; i++)
Serial.print(rgbRead[i], BYTE);
Serial.println("");
udpClient.writeDatagram(rgbRead, cbRead);
state = READ;
break;
// close our udpClient and go back to listening
case CLOSE:
udpClient.close();
Serial.println("Closing UdpClient");
Serial.println("");
break;
// something bad happen, just exit out of the program
case EXIT:
udpClient.close();
udpServer.close();
Serial.println("Something went wrong, sketch is done.");
state = DONE;
break;
// do nothing in the loop
case DONE:
default:
break;
// every pass through loop(), keep the stack alive
DNETcK::periodicTasks();
Then I tried it with PlatformIO by including the same libraries in .platformio/lib/ and it didn’t work. I also tried to put those libraries directly in the project folder (in the lib folder) and I even sorted the libraries using the recommended method (with the scr folder into the folder of the library). It didn’t work either. I always get the same error that makes me think that the library isn’t well included :
[Tue Sep 6 15:21:53 2016] Processing chipkit_uc32 (platform: microchippic32, board: chipkit_uc32, framework: arduino)
Collected 34 compatible libraries
Looking for dependencies...
Warning! Circular dependencies detected between `/media/byran/Données/PlatformIOProjectsLinux/TestENC28J60/lib/DWIFIcK` and `/media/byran/Données/PlatformIOProjectsLinu
x/TestENC28J60/lib/DNETcK`
Warning! Circular dependencies detected between `/home/byran/.platformio/packages/framework-arduinomicrochippic32/libraries/IM8720PHY` and `/home/byran/.platformio/pack
ages/framework-arduinomicrochippic32/libraries/DEIPcK`
Library Dependency Graph
|-- <DNETcK>
| |-- <PmodNIC>
|-- <PmodNIC>
/home/byran/.platformio/packages/tool-scons/script/../engine/SCons/Environment.py:1322: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
val = [x for x in val if x not in dk]
Compiling .pioenvs/chipkit_uc32/src/UDPEchoServer2.o
Compiling .pioenvs/chipkit_uc32/FrameworkArduino/crtn.o
Compiling .pioenvs/chipkit_uc32/FrameworkArduino/doprnt.o
src/UDPEchoServer2.c:80:1: error: unknown type name 'IPv4'
IPv4 ipServer = {192,168,1,190};
src/UDPEchoServer2.c:110:1: error: unknown type name 'UdpClient'
src/UDPEchoServer2.c:110:40: error: expected ')' before 'sizeof'
src/UDPEchoServer2.c:115:6: error: variably modified 'rgbUDPServerCache' at file scope
src/UDPEchoServer2.c:116:1: error: unknown type name 'UdpServer'
src/UDPEchoServer2.c:116:40: error: expected ')' before 'sizeof'
src/UDPEchoServer2.c:118:7: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
src/UDPEchoServer2.c: In function 'setup':
src/UDPEchoServer2.c:146:5: error: 'Serial' undeclared (first use in this function)
Serial.begin(9600);
src/UDPEchoServer2.c:146:5: note: each undeclared identifier is reported only once for each function it appears in
src/UDPEchoServer2.c:152:12: error: expected expression before ':' token
src/UDPEchoServer2.c: In function 'loop':
src/UDPEchoServer2.c:183:12: error: 'udpServer' undeclared (first use in this function)
src/UDPEchoServer2.c:185:13: error: 'Serial' undeclared (first use in this function)
src/UDPEchoServer2.c:199:35: error: 'status' undeclared (first use in this function)
src/UDPEchoServer2.c:202:38: error: 'DEC' undeclared (first use in this function)
src/UDPEchoServer2.c:206:17: error: 'DNETcK' undeclared (first use in this function)
src/UDPEchoServer2.c:206:23: error: expected ')' before ':' token
src/UDPEchoServer2.c:228:9: error: 'udpClient' undeclared (first use in this function)
udpClient.close();
src/UDPEchoServer2.c:274:9: error: 'for' loop initial declarations are only allowed in C99 mode
src/UDPEchoServer2.c:274:9: note: use option -std=c99 or -std=gnu99 to compile your code
src/UDPEchoServer2.c:276:38: error: expected expression before 'BYTE'
src/UDPEchoServer2.c:308:12: error: expected expression before ':' token
*** [.pioenvs/chipkit_uc32/src/UDPEchoServer2.o] Error 255
Compiling .pioenvs/chipkit_uc32/FrameworkArduino/exceptions.o
========================== [ERROR] Took 1.97 seconds ==========================
Do I make a mistake when I copy the libraries in the folders I mentionned before ?
