I confirmed this library was meant to work both with and without the Arduino framework, yet Platformio’s library manager refuses to use unless the lib_compat_mode = soft
is added when the Arduino framework isn’t used.
So, we created a library.json file that doesn’t specify the Arduino framework is required and would like to use that file instead of the library.properties file that was used for the register.
