I’m using an Esp-01 and an usb to ttl serial converter for serial communication.
If I use the PlatformIO’s buildt in serial monitor, it only shows NULL’s instead of characters, but if I try it with the same BAUD-rate at Arduino IDE, it works correctly.
What’s the problem with the PlatfomIO’s serial monitor, what do I need to change in the setups?
Thanks: T
EDIT: It seem’s to appear only in this code, and maybe caused by the “BUILTIN_LED” constant.
pinMode(BUILTIN_LED, OUTPUT);
Serial.begin(9600);
digitalWrite(BUILTIN_LED, HIGH);
delay(1000); // wait for a second
digitalWrite(BUILTIN_LED, LOW);
Serial.println("Beep!");
