I am (starting to) integrate a framework into platformio.
Have python 2.7 installed and can run platformio from command prompt and “see” it as a package (?) within python.
Have downloaded the github/platformio/platformio repository to my local system.
First questions :
- How go I get my installed platformio working with my local repository instead of “remote standard one”
- Where is the “content” of the packages defined
f.e. the sdk-esp8266 for espressif platform. I do need to add some of 9(like) these
Hi @hreintke
Here are steps from our contributing manual:
- Fork the repository on GitHub.
- Make a branch
- Run pip install
tox
- Go to the root of project where is located tox.ini and run
tox -e develop
- Activate current development environment:
- Windows:
.tox\develop\Scripts\activate
- Bash/ZSH:
source .tox/develop/bin/activate
- Fish:
source .tox/bin/activate.fish
- Make changes to code, documentation, etc.
All packages are located in PlatformIO home directory:
/home/user/.platformio/packages C:\Users\User\.platformio\packages
Thanks for the quick answer.
I had seen that page but did not realize that this is pointing platformio.exe to the local repo.
Tried & questioned otherwise because I get a “Interpreter not found” error on the tox - e develop line.
Searched the internet for that and installed the suggested pypy package with no better result.
On commandline I can run “pyhton” & “pypy” without issues, so PATH should be OK.
Any hints where I could find a solution for this ?
I hacked my way around the interpreter not found issue by replacing the :
[testenv:develop]
basepython = python2.7
usedevelop = True
deps =
isort
flake8
commands = python --version
in the tox.ini to :
basepython=python
Do you expect any issues with that, or any other updates that may be required ?
On the packages :
The “installed packages” are located in the C:\Users\User.platformio\packages directory.
My question is about to define a package.
Suppose I want to add a package called “my_package” the espressif platform.
As far as I understand now, I need to add :
“my_package”: {
to the espressif.py platforms file.
But where do I define which files are within the package and where to download them from ?
Have been checking python sources in the github.
Is it correct that this is somewhere in a manifest file ?
If so : can you point me to the documentation of that manifest file and/or example of manifest fro one of the installed frameworks
PS :Should I create a new topic so that the questions match the header ?
Yes, please create separate subject and I’ll explain to you how to create own development platform or use existing with PlatformIO 3.0.
