I have modified the platformio.ini file as requested. I can confirm that it is working and I am able to upload my code to Arduino Uno Wifi Rev 2 without any issue. I also attached the verbose upload output for your reference if needed. Thanks again for the quick fix.
> Executing task in folder Robot Arm Braccio: C:\Users\Wong Zhi Wei\.platformio\penv\Scripts\platformio.exe run --verbose --target upload --environment uno_wifi_rev2 <
Processing uno_wifi_rev2 (platform: https://github.com/platformio/platform-atmelmegaavr.git; board: uno_wifi_rev2; framework: arduino; lib_deps: arduino-libraries/Braccio@^2.0.4, arduino-libraries/Servo@^1.1.8)
----------------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/atmelmegaavr/uno_wifi_rev2.html
PLATFORM: Atmel megaAVR (1.5.0+sha.317e3e8) (git+https://github.com/platformio/platform-atmelmegaavr.git) > Arduino Uno WiFi Rev2
HARDWARE: ATMEGA4809 16MHz, 6KB RAM, 47.50KB Flash
 - framework-arduino-megaavr 1.8.7
 - tool-avrdude-megaavr 1.60300.191015 (6.3.0)
 - toolchain-atmelavr 1.70300.191015 (7.3.0)
Found 7 compatible libraries
|-- <Braccio> 2.0.4 (D:\Nextcloud\PlatformIO\Project\Robot Arm Braccio\.pio\libdeps\uno_wifi_rev2\Braccio)
|   |-- <Servo> 1.1.8 (D:\Nextcloud\PlatformIO\Project\Robot Arm Braccio\.pio\libdeps\uno_wifi_rev2\Servo)
MethodWrapper(["checkprogsize"], [".pio\build\uno_wifi_rev2\firmware.elf"])
RAM:   [          ]   1.5% (used 90 bytes from 6144 bytes)
Flash: [=         ]   7.6% (used 3714 bytes from 48640 bytes)
.pio\build\uno_wifi_rev2\firmware.elf  :
section                     size      addr
.data                         14   8398848
.text                       3536       512
.rodata                      164     20432
.bss                          76   8398862
.comment                      17         0
.note.gnu.avr.deviceinfo      64         0
.debug_aranges               416         0
.debug_info                11869         0
.debug_abbrev               9132         0
.debug_line                 2445         0
.debug_str                  3979         0
Total                      31712
<lambda>(["upload"], [".pio\build\uno_wifi_rev2\firmware.hex"])
AVAILABLE: xplainedmini_updi
CURRENT: upload_protocol = xplainedmini_updi
BeforeUpload(["upload"], [".pio\build\uno_wifi_rev2\firmware.hex"])
avrdude -v -p atmega4809 -C "C:\Users\Wong Zhi Wei\.platformio\packages\tool-avrdude-megaavr\avrdude.conf" -c xplainedmini_updi -Ufuse2:w:0x01:m -Ufuse5:w:0xC9:m -Ufuse8:w:0x02:m -Ulock:w:0xC5:m -U "flash:w:C:\Users\Wong Zhi Wei\.platformio\packages\framework-arduino-megaavr\bootloaders\atmega4809_uart_bl.hex:i" -b 115200 -V -e -D -P usb -U flash:w:.pio\build\uno_wifi_rev2\firmware.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Wong Zhi Wei\.platformio\packages\tool-avrdude-megaavr\avrdude.conf"
         Using Port                    : usb
         Using Programmer              : xplainedmini_updi
         Overriding Baud Rate          : 115200
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
         AVR Part                      : ATmega4809
         Chip Erase delay              : 0 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 0
         StabDelay                     : 0
         CmdexeDelay                   : 0
         SyncLoops                     : 0
         ByteDelay                     : 0
         PollIndex                     : 0
         PollValue                     : 0x00
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           prodsig        0     0     0    0 no         61   61      0     0     0 0x00 0x00
           fuses          0     0     0    0 no          9    0      0     0     0 0x00 0x00
           fuse0          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse1          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse2          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse4          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse5          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse6          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse7          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse8          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0     0     0 0x00 0x00
           data           0     0     0    0 no          0    0      0     0     0 0x00 0x00
           usersig        0     0     0    0 no         64   64      0     0     0 0x00 0x00
           flash          0     0     0    0 no      49152  128      0     0     0 0x00 0x00
           eeprom         0     0     0    0 no        256   64      0     0     0 0x00 0x00
         Programmer Type : JTAGICE3_UPDI
         Description     : Atmel AVR XplainedMini in UPDI mode
         ICE hardware version: 0
         ICE firmware version: 1.19 (rel. 57)
         Serial number   : 3E8AF0BC6CAE72168E44
         Vtarget         : 5.00 V
         JTAG clock megaAVR/program: 0 kHz
         JTAG clock megaAVR/debug:   0 kHz
         JTAG clock Xmega: 0 kHz
         PDI clock Xmega : 0 kHz
avrdude: Partial Family_ID returned: "mega"
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e9651 (probably m4809)
avrdude: erasing chip
avrdude: reading input file "0x01"
avrdude: writing fuse2 (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of fuse2 written
avrdude: verifying fuse2 memory against 0x01:
avrdude: load data fuse2 data from input file 0x01:
avrdude: input file 0x01 contains 1 bytes
avrdude: reading on-chip fuse2 data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of fuse2 verified
avrdude: reading input file "0xC9"
avrdude: writing fuse5 (1 bytes):
avrdude: 1 bytes of fuse5 written
avrdude: verifying fuse5 memory against 0xC9:
avrdude: load data fuse5 data from input file 0xC9:
avrdude: input file 0xC9 contains 1 bytes
avrdude: reading on-chip fuse5 data:
avrdude: WARNING: invalid value for unused bits in fuse "fuse5", should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xcd instead of 0xc9 (double check with your datasheet first).
avrdude: 1 bytes of fuse5 verified
avrdude: reading input file "0x02"
avrdude: writing fuse8 (1 bytes):
avrdude: 1 bytes of fuse8 written
avrdude: verifying fuse8 memory against 0x02:
avrdude: load data fuse8 data from input file 0x02:
avrdude: input file 0x02 contains 1 bytes
avrdude: reading on-chip fuse8 data:
avrdude: 1 bytes of fuse8 verified
avrdude: reading input file "0xC5"
avrdude: writing lock (1 bytes):
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0xC5:
avrdude: load data lock data from input file 0xC5:
avrdude: input file 0xC5 contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock verified
avrdude: reading input file "C:\Users\Wong Zhi Wei\.platformio\packages\framework-arduino-megaavr\bootloaders\atmega4809_uart_bl.hex"
avrdude: writing flash (280 bytes):
Writing | ################################################## | 100% 0.12s
avrdude: 280 bytes of flash written
avrdude: verifying flash memory against C:\Users\Wong Zhi Wei\.platformio\packages\framework-arduino-megaavr\bootloaders\atmega4809_uart_bl.hex:
avrdude: load data flash data from input file C:\Users\Wong Zhi Wei\.platformio\packages\framework-arduino-megaavr\bootloaders\atmega4809_uart_bl.hex:
avrdude: input file C:\Users\Wong Zhi Wei\.platformio\packages\framework-arduino-megaavr\bootloaders\atmega4809_uart_bl.hex contains 280 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.10s
avrdude: 280 bytes of flash verified
avrdude: reading input file ".pio\build\uno_wifi_rev2\firmware.hex"
avrdude: writing flash (4226 bytes):
Writing | ################################################## | 100% 1.06s
avrdude: 4226 bytes of flash written
avrdude: safemode: Fuses OK (E:FF, H:FF, L:FF)
avrdude done.  Thank you.
==================================================================== [SUCCESS] Took 3.97 seconds ====================================================================
