Yes, since that’s exactly what would be called if the normal way of just opening a CLI and running pio would do.
Shortcut reasons. Usually you do not have to specify the entire path to pio exe, PlatformIO nicely prepares the environment in the PlatformIO CLI terminal.
Firstly, make sure you are using the VSCode (PIO IDE) version only. See Multiple PlatformIO Cores in a system and ‘platformio’ is not recognized as an internal or external command
The following is an extract from the official guide
An alternative way to do this is to click the PIO icon on the left
Then go to Quick Access > Miscellaneous > PlatformIO Core CLI
Then you should be able to run pio commands in the integrated terminal
Try:
pio --version
which should return something like
PlatformIO Core, version 6.1.16
