On one of my machines AMD Ryzen/Win10 PlatformIO does not work for some time. Don’t no for how long. Recocknized when playing around with serveral IDEs as ATMEL Studio, Eclipse/Sloeber/STM32CUBE and Arduino and judging PlatformIO as the the one to go with, it wasn’t working any more.
However, VSC/PlatformIO does not give any error message, but the terminal accepts no input and when I start a build process I get the Message “Executing task in folder 191219-225226-arduino-blink: C:\Users\thomas.platformio\penv\Scripts\platformio.exe run <” and thats it, building indication will circle forever.
Toggleing developer tools gives me the following error messages:
bootstrap-window.js:213 [uncaught exception]: Error: connect ENOENT \\.\pipe\winpty-conin-908-1-1d5b8fc98f86194-807a7b94bc2c9c1c427485d15ce21821 onUnexpectedError @ bootstrap-window.js:213 bootstrap-window.js:216 Error: connect ENOENT \\.\pipe\winpty-conin-908-1-1d5b8fc98f86194-807a7b94bc2c9c1c427485d15ce21821 at PipeConnectWrap.afterConnect [as oncomplete] (net.js:1054) onUnexpectedError @ bootstrap-window.js:216 events.js:177 Uncaught Error: connect ENOENT \\.\pipe\winpty-conin-908-1-1d5b8fc98f86194-807a7b94bc2c9c1c427485d15ce21821 at PipeConnectWrap.afterConnect [as oncomplete] (net.js:1054) bootstrap-window.js:213 [uncaught exception]: Error: connect ENOENT \\.\pipe\winpty-conout-908-2-1d5b8fc98f86194-9c9f9d0b2c609e442eb4b2da6829d84c onUnexpectedError @ bootstrap-window.js:213 bootstrap-window.js:216 Error: connect ENOENT \\.\pipe\winpty-conout-908-2-1d5b8fc98f86194-9c9f9d0b2c609e442eb4b2da6829d84c at PipeConnectWrap.afterConnect [as oncomplete] (net.js:1054) onUnexpectedError @ bootstrap-window.js:216 events.js:177 Uncaught Error: connect ENOENT \\.\pipe\winpty-conout-908-2-1d5b8fc98f86194-9c9f9d0b2c609e442eb4b2da6829d84c at PipeConnectWrap.afterConnect [as oncomplete] (net.js:
The most weird:
I uninstalled extensions (PlatformIO, GitLens, C/C++Ext), uninstalled VSC, run CCleaner, rebooted and installed VSC again in System mode. All easy.
After first start of VNC, console was empy - no errors. When installing extensions a Buffer DeprecationWarning showed up but installation for all three extensions was confirmed.
Since terminal was working I started a build of arduino blink example - all went fine everything seemed perfect. But …
Closing VSC and starting it again brings back the problem. On VSC startup PlatformIO was running an update and I got the message PlatformIO Core was updated sucessfully. Now the terminal is dead again and ENOENT connect errors are back.
Any suggestions?
