I’m using monitor_filters=send_on_enter
in platformio.ini
I know PIO using miniterm.py
i realized PIO send Carriage Return (CR) Line Feed (LF) at send_on_enter.
It doesn’t want to send with pressing enter if I set line ending with LF only or CR only that I was setup with CTRL+L.
monitor_eol
= LF
in the platformio.ini
does not help?
Some of the monitor stuff changes with the recent updates to 6.1. The docs are updated and at Redirecting.... I fell foul of this myself when my monitor_flags
, in an old project, now have their own settings.
You should see a warning messages advising that some of the monitor_filters
were invalid where they used to be valid before if this is happening to you.
Mine used to be:
; Serial Monitor options
monitor_filters = send_on_enter
monitor_flags =
--echo
--eol
CRLF
and now they are:
monitor_echo = yes
monitor_eol = CRLF
HTH
Cheers,
Norm.
