For some reason I have started getting the following error regardless of what project I have opened even those which no dependencies. How can I fix this. ( The file it refers to does exist )
In file included from C:\Users\USERNAME\.platformio\packages\framework-arduino-avr\cores\arduino\USBAPI.h:33:0,
from C:\Users\USERNAME\.platformio\packages\framework-arduino-avr\cores\arduino\USBCore.cpp:20:
C:\Users\Terry\.platformio\packages\framework-arduino-avr\cores\arduino\Arduino.h:233:10: fatal error: HardwareSerial.h: No such file or directory
/** UPDATE **/
I tried a clean uninstall and reinstall, and even with a virgin project I still get the the error.
* Looking for HardwareSerial1.h dependency? Check our library registry!
* CLI > platformio lib search "header:HardwareSerial1.h"
* Web > https://registry.platformio.org/search?q=header:HardwareSerial1.h
#include "HardwareSerial1.h"
compilation terminated.
*** [.pio\build\nanoatmega328new\FrameworkArduino\HardwareSerial1.cpp.o] Error 1
======================================================================================== [FAILED] Took 1.68 seconds ========================================================================================
* The terminal process "C:\Users\USER\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Thanks
