Hi there,
just wonder how I can specify when I create a arduini cpp main.cpp prject that the library should be used from the lib path instead of the general library.
is a
#include “local_lib.c”
the only thing or do I need to install the lib with the Lib Manager as well?
You include a .c
file? Anyways, it should work out of the box if you just create a new folder in lib/
with the folder structure described in the readme.txt
in there and include the header file from your main code. If it doesn’t work come back with a concrete error and your project setup.
Hey there,
I am trying to understand the difference between
and
#include <local_lib.c>
as well as the option to include Libraries with the Library Manage global and on a project basis as well as copy and past below the project lib folder.
