Platformio non compila
Salve a tutti sono nuovo nel forum e non riesco a compilare tramite platformio… mi si blocca a questo punto…
  • Esecuzione dell’attività: C:\Users\utente.platformio\penv\Scripts\platformio.exe run
Warning! Ignore unknown configuration option monitor_flags in section [env]
Warning! src_filter configuration option in section [env:SAMD51_grandcentral_m4] is deprecated and will be removed in the next release! Please use build_src_filter instead
Warning! src_filter configuration option in section [env:malyan_M300] is deprecated and will be removed in the next release! Please use build_src_filter instead
Warning! src_filter configuration option in section [env:esp32] is deprecated and will be removed in the next release! Please use build_src_filter instead
Warning! src_filter configuration option in section [env:teensy31] is deprecated and will be removed in the next release! Please use build_src_filter instead
Warning! src_filter configuration option in section [env:teensy35] is deprecated and will be removed in the next release! Please use build_src_filter instead
Warning! src_filter configuration option in section [env:teensy36] is deprecated and will be removed in the next release! Please use build_src_filter instead
Warning! src_filter configuration option in section [env:teensy41] is deprecated and will be removed in the next release! Please use build_src_filter instead
Warning! src_build_flags configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use build_src_flags instead
Warning! src_filter configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use build_src_filter instead
Warning! src_filter configuration option in section [env:include_tree] is deprecated and will be removed in the next release! Please use build_src_filter instead
Processing mks_robin_nano35 (platform: ststm32@~10.0; board: genericSTM32F103CB; framework: arduino)
---------------------------------------------------------------------------------------------Verbose mode can be enabled via -v, --verbose option
Copying MKS Assets
CONFIGURATION: Redirecting...
PLATFORM: ST STM32 (10.0.1) > STM32F103CB (20k RAM. 128k Flash)
HARDWARE: STM32F103CBT6 72MHz, 20KB RAM, 128KB Flash
DEBUG: Current (jlink) External (blackmagic, cmsis-dap, jlink, stlink)
  • framework-arduinoststm32-maple @ 3.10000.201129 (1.0.0)
  • tool-stm32duino @ 1.0.2
  • toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
    Converting Marlin.ino
    Found 31 compatible libraries
    Scanning dependencies…
    |-- SoftwareSerialM @ 1.0.0
    |-- lvgl @ 6.1.1
    |-- qr_encode @ 0.0.0+20201117144502
    |-- TMCStepper @ 0.7.3
    |-- STM32ADC @ 1.0
    |-- EEPROM
    |-- USBComposite for STM32F1 @ 0.99
    |-- Wire @ 1.0
    |-- Servo(STM32F1) @ 1.1.2
    Compiling .pio\build\mks_robin_nano35\FrameworkArduinoVariant\board.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduinoVariant\wirish\boards.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduinoVariant\wirish\boards_setup.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduinoVariant\wirish\start.S.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduinoVariant\wirish\start_c.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduinoVariant\wirish\syscalls.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\HardwareSerial.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\HardwareTimer.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\IPAddress.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\Print.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\Stream.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\WString.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\avr\dtostrf.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\cxxabi-compat.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\ext_interrupts.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\hooks.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\itoa.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\adc.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\adc_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\bkp_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\dac.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\dma.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\dma_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\exc.S.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\exti.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\exti_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\flash.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\fsmc_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\gpio.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\gpio_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\i2c.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\i2c_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\iwdg.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\nvic.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\pwr.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\rcc.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\rcc_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\spi.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\spi_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\stm32f1\performance\isrs.S.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\stm32f1\performance\vector_table.S.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\systick.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\timer.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\timer_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usart.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usart_f1.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usart_private.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usb\stm32f1\usb.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usb\stm32f1\usb_cdcacm.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usb\stm32f1\usb_reg_map.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usb\usb_lib\usb_core.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usb\usb_lib\usb_init.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usb\usb_lib\usb_mem.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\usb\usb_lib\usb_regs.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\libmaple\util.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\main.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\new.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\pwm.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\sdio.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\stm32f1\util_hooks.c.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\stm32f1\wirish_debug.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\stm32f1\wirish_digital_f1.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\tone.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\usb_serial.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\wirish_analog.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\wirish_digital.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\wirish_math.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\wirish_shift.cpp.o
    Compiling .pio\build\mks_robin_nano35\FrameworkArduino\wirish_time.cpp.o
    Compiling .pio\build\mks_robin_nano35\src\src\HAL\STM32F1\HAL.cpp.o
    Compiling .pio\build\mks_robin_nano35\src\src\HAL\STM32F1\HAL_SPI.cpp.o
    Compiling .pio\build\mks_robin_nano35\src\src\HAL\STM32F1\MarlinSerial.cpp.o
    Compiling .pio\build\mks_robin_nano35\src\src\HAL\STM32F1\SPI.cpp.o
provato e riprovato a disinstallare tutto e reinstallare ma niente da fare… qualcuno può aiutarmi?
