Hey, I want to build a specific example, e.g. examples/PM25_test/PM25_test.ino and to reference the root folder for includes (lib_dir, lib_extra_dirs, build_src_filter, build flag -I.) in the “most correct” way.
I appreciate that not having the library code, and main code file (examples), in the src folder is going against the platformIO desires. Ignoring what platformIO wants, is what I’m asking possible without refactoring the file tree?
I have had some hacky build settings work, but not reliably on another machine, I’ve clearly not quite got it write (and now changed too many times). Simplest win is to copy the sketch to root folder, but that’s not what I want as it alters the file tree along with duplicating examples.
PlatformIO.ini contents (with example copied to root):
[platformio]
description = "Adafruit PM2.5 Sensor Library"
default_envs = adafruit_feather_esp32s3, raspberypi_pico, arduino_nano_new_bootloader, huzzah, adafruit_pyportal_m4
src_dir = ./
[env]
Adafruit BusIO
Adafruit SH110X
; ${PROJECT_DIR}/
[common:esp32]
Adafruit BusIO
ESPSoftwareSerial
; ${PROJECT_DIR}/
monitor_filters = esp32_exception_decoder, time
[common:esp8266]
platform = espressif8266
lib_ignore =
[common:atsamd]
platform = atmelsam
platform_packages =
platformio/framework-arduino-samd-adafruit@^1.7.13
platformio/tool-jlink@^1.78811.0
lib_ldf_mode = chain+
lib_compat_mode = strict
lib_archive = no
lib_ignore =
[common:rp2040]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git#develop
board = rpipicow
board_build.core = earlephilhower
board_build.filesystem_size = 0.5m
build_flags = -DUSE_TINYUSB
lib_ignore =
lib_compat_mode = soft
[common:avr]
[env:arduino_uno]
extends = common:avr
board = uno
; ESP32 Boards:
[env:featheresp32]
extends = common:esp32
board = featheresp32
build_flags = -DARDUINO_FEATHER_ESP32
board_build.partitions = min_spiffs.csv
; Adafruit Feather ESP32-S3 2MB PSRAM
[env:adafruit_feather_esp32s3]
board = adafruit_feather_esp32s3
build_flags = -DARDUINO_ADAFRUIT_FEATHER_ESP32S3 -DBOARD_HAS_PSRAM
; Adafruit Feather ESP32-S3 NO PSRAM
[env:adafruit_feather_esp32s3_nopsram]
board = adafruit_feather_esp32s3_nopsram
build_flags = -DARDUINO_ADAFRUIT_FEATHER_ESP32S3_NOPSRAM
; Raspberry Pi RP2040/RP2350 boards
[env:raspberypi_pico]
extends = common:rp2040
board = rpipico
[env:raspberypi_picow]
[env:raspberypi_pico2w]
board = rpipico2w
; Arduino AVR Boards
[env:arduino_nano_new_bootloader]
board = nanoatmega328new
[env:arduino_nano_old_bootloader]
; ESP8266 Boards
; Adafruit Feather HUZZAH ESP8266
[env:huzzah]
extends=common:esp8266
board = huzzah
board_build.f_cpu = 80000000L
; Arduino CLI uses this from adafruit_ci#ci-wippersnapper
; esp8266:esp8266:huzzah:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200
-Wl,--gc-sections
-Wl,-Map=output.map
-DARDUINO_ESP8266_ADAFRUIT_HUZZAH
-DDEBUG_ESP_PORT=Serial
-DVTABLES_IN_FLASH
-DNO_EXCEPTIONS
-DNO_STACK_SMASH_PROTECTION
-DSSL_ALL
-DMMU_3232
-DNON32XFER_FAST
-DDEBUG_DISABLED
-DDEBUG_LEVEL_NONE
board_build.eesz=4M2M
; SAMD51 Boards ;
; Adafruit PyPortal M4
[env:adafruit_pyportal_m4]
extends = common:atsamd
board = adafruit_pyportal_m4
-DADAFRUIT_PYPORTAL
