i did it and my username is in the group. actually i figured out where the problem comes from, but i can’t fix it.
when i type command lsusb → Bus 001 Device 009: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
but in the rules → sudo nano /etc/udev/rules.d/99-platformio-udev.rules →
CP210X USB UART
ATTRS{idVendor}==“10c4”, ATTRS{idProduct}==“ea[67][013]”, MODE:=“0666”, ENV{ID_>
ATTRS{idVendor}==“10c4”, ATTRS{idProduct}==“80a9”, MODE:=“0666”, ENV{ID_MM_DE
but when i convert it to my UID and VID, the problem is not solved and i see this error →
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Checking size .pio/build/esp32dev/firmware.elf
RAM: [= ] 6.4% (used 21032 bytes from 327680 bytes)
Flash: [== ] 17.8% (used 233185 bytes from 1310720 bytes)
Configuring upload protocol…
Warning! Your /etc/udev/rules.d/99-platformio-udev.rules
are outdated. Please update or reinstall them.
More details: 99-platformio-udev.rules — PlatformIO latest documentation
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port…
Auto-detected: /dev/ttyUSB0
Uploading .pio/build/esp32dev/firmware.bin
esptool.py v4.5.1
Serial port /dev/ttyUSB0
Connecting…
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
*** [upload] Error 2
================================= [FAILED] Took 10.45 seconds =================================
