That’s a cool feature to have. Many thanks.
I just wonder if it’s possible to replace [F3] with [Ctrl]+[Left Mouse Button Click]?
We are working on it. We will inform later when this feature will be available.
Hi Ivan,
are there any requirements to use the “Jump to declaration” feature? I freshly installed IDE 1.2.2 and set up a basic Blink sketch. But when I want to jump to the “digitalWrite” declaration for example (using F3 shortkey) nothing happens.
I found out that in the context menu there are two entries: “Goto declaration” and “Go to declaration”. Might there be a conflict that prevents the feature from working?
Best regards,
Thomas
Hi,
Is your sketch with *.cpp/*.c
extension?
Yes. The source file is named “Blink.cpp” and contains the default Arduino Blink example - just with the additional “Arduino.h” include.
Unfortunately I cannot find any Atom syslog file to find out what’s going on…
Menu: PlatformIO > Rebuild C/C++ index
Index is rebuilt and auto completion does work flawlessly. It’s just as if F3 is not bound to anything - but it is as settings menu shows…
Did you try 2 different “Go to declarations” from the context menu?
I did. The “Goto Declaration” item highlights the method the cursor in on, the “Go to Declaration” doesn’t do anything a all.
Please provide:
platformio.ini
Menu: View > Developer > Toggle Developer Tools > Console
).Thanks.
OS Type:
Windows 10 64bit
platform.ini
[env:nanoatmega328]
platform = atmelavr
board = nanoatmega328
Log:
In file included from <stdin>:16:
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:155:23: warning: unknown attribute __progmem__ ignored [-Wunknown-attributes]
extern const uint16_t PROGMEM port_to_mode_PGM[];
autocomplete-clang.coffee:87 C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\avr/pgmspace.h:109:17: note: expanded from macro 'PROGMEM'
#define PROGMEM __ATTR_PROGMEM__
C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\avr/pgmspace.h:95:41: note: expanded from macro '__ATTR_PROGMEM__'
#define __ATTR_PROGMEM__ __attribute__((__progmem__))
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:156:23: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint16_t PROGMEM port_to_input_PGM[];
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:157:23: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint16_t PROGMEM port_to_output_PGM[];
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:159:22: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint8_t PROGMEM digital_pin_to_port_PGM[];
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:161:22: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[];
autocomplete-clang.coffee:87 C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\avr/pgmspace.h:95:41: note: expanded from macro '__ATTR_PROGMEM__'
C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:162:22: warning: unknown attribute '__progmem__' ignored [-Wunknown-attributes]
extern const uint8_t PROGMEM digital_pin_to_timer_PGM[];
autocomplete-clang.coffee:87 In file included from <stdin>:16:
In file included from C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino\Arduino.h:225:
In file included from C:\Users\Thomas\.platformio\packages\framework-arduinoavr\cores\arduino/USBAPI.h:27:
In file included from C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\util/delay.h:43:
C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\util/delay_basic.h:108:5: error: invalid output constraint '=w' in asm
: "=w" (__count)
C:\Users\Thomas\.platformio\packages\toolchain-atmelavr\avr\include\util/delay.h:95:3: warning: "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed" [-W#warnings]
# warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
autocomplete-clang.coffee:87 7 warnings and 1 error generated.
@valeros has just checked it under Windows and reported that this feature does not work. @DerTomm please open an issue here: GitHub - platformio/platformio-atom-ide: PlatformIO IDE for Atom: The next generation integrated development environment for IoT
P.S: It works very well under Unix.
Done.
Good to know
Hello, are there any news on this issue?
We work on the big update for PlatformIO IDE 2.0. I hope after that we will resolve this issue.
This is good to know, is there an estimate release date?
It will be good to have first public beta this year
@ivankravets unfortunately I was a bit busy and I didn’t had the chance to check the progress on this issue.
Has the beta been released to the public? Is the feature working on windows?
I really like this feature when I have a lot of code lines written
We haven’t released PIO IDE 2.0 yet. However, we announced the first public Preview. See
Hi, Ivan.
I’m also having trouble with “go to declaration”. I did ask on the Atom.io board at Sunsetting Atom | The GitHub Blog as well and I was referred to this board.
Info:
Debian Stable (Platform.IO 3.5.3a8 on Atom.IO)
platformio.ini
platform=espressif32
board=esp32dev
framework=arduino
monitor_baud=115200
[platformio]
src_dir=.
lib_extra_dirs = …/…/libraries
Log
autocomplete-clang.coffee? [sm]:86 GoDecl err
clang: error: no input files
Error message above was the result of opening the telelogger project and trying to navigate, for example, from initialize() in line 976. This is just an example, no similar jumps work anywhere in any of the Arduino sketches I am trying.
Could you please tell me what I am doing wrong?
Thanks,
Andrea.
