Why does’t IDE recognize `“genericSTM32F103RC” ? I’ve tried everything I can think of (total amateur) with no luck. Can anyone help?
Do you have an error message or a screenshot to show that the problem is?
pio init -b genericSTM32F103RC
works on my machine just fine.
That’s a different thing. As a value for default_envs
, you can only give the name of an environment that exists in the platformio.ini
(or .ini
files it includes). So, if there is no [env: genericSTM32F103RC]
, you cannot do default_envs = genericSTM32F103RC
The Marlin project contains lots of environments, some of which are STM32F103RC based. In particular, you seem to be working with a SKR Mini E3 V2.0, judging from the name of the workspace. The official repository for that device’s firmware device is already setup correctly:
So I’m not sure why you deviated from the good defaults to something that doesn’t work.
