I got a problem that I cannot compile my ESP32 module (ESP32_DEVKITC_V4 or ESP32S) when I use platformio, but both are workable on Arduino IDE.
the error code on platformio as below,
Auto-detected: COM7
Uploading .pio\build\uno\firmware.hex
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x66
avrdude done. Thank you.
*** [upload] Error 1
================================================================================================= [FAILED] Took 103.64 seconds =================================================================================================
The terminal process "C:\Users\John Lin\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
