I’ve tried to compile/build esp8266 firmware from VSCode with Platformio IDE, but when I try to compile/build it show:
platformio.exe run < failed to create process
I’ve tried uninstall the Platformio IDE extension from VSCode, remove the content on .platformio folder, restart the IDE, and install Platformio IDE again (like clean install), but it still return failed to create process error message (even if I run VSCode under administrator)
I’m also have tried to run platformio.exe (just type platformio.exe) manually using terminal (command prompt) even with administrator privilege, the execute also return failed to create process (on terminal/command prompt). so right now I’m stuck on how to compile/build my code.
For information, I use Platformio Core version 5.2.5; Windows 11;
