Hi!
I am a little frustrated with the platformio:
Somehow it does not upload anything to my arduino unit board though it says it does.
It took me some time to get to this point.
Here is a simple sketch that I ran in the Arduino Software and uploaded it:
#include <Wire.h>
#include <RTC.h>
static DS3231 RTC;
void setup()
Serial.begin(9600);
RTC.begin();
void loop()
int yearNow;
int monthNow, dateNow, hourNow, minuteNow, secondNow, weekNow;
if (RTC.isRunning())
yearNow=RTC.getYear();
monthNow =RTC.getMonth();
dateNow=RTC.getDay();
weekNow=RTC.getWeek();
hourNow=RTC.getHours();
minuteNow=RTC.getMinutes();
secondNow=RTC.getSeconds();
Serial.print("Weekday: ");
Serial.print(weekNow);
Serial.print(" Time:");
// Finally the hour, minute, and second
Serial.print(hourNow);
Serial.print("-");
Serial.print(minuteNow);
Serial.print("-");
Serial.print(secondNow);
Serial.print(" ## ");
Serial.print("Date: ");
Serial.print(yearNow);
Serial.print("/");
Serial.print(monthNow);
Serial.print("/");
Serial.println(dateNow);
This is what I get then in serial monitor as expected:
Weekday: 5 Time:9-19-50 ## Date: 2020/7/29
I ran the same sketch in the Visual Studio Code on Mac OSX 10.13.6 with this compilation results:
Processing uno (platform: atmelavr; board: uno; framework: arduino)
Verbose mode can be enabled via-v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Atmel AVR 2.2.0 > Arduino Uno
- framework-arduino-avr 5.0.0
Found 5 compatible libraries
Scanning dependencies…
Checking size .pio/build/uno/firmware.elf
RAM: [ ] 0.4% (used 9 bytes from 2048 bytes)
Flash: [ ] 1.4% (used 444 bytes from 32256 bytes)
Configuring upload protocol…
AVAILABLE: arduino
Looking for upload port…
Auto-detected: /dev/cu.usbmodem1411
Uploading .pio/build/uno/firmware.hexavrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e950f (probably m328p) avrdude: reading input file ".pio/build/uno/firmware.hex" avrdude: writing flash (444 bytes): Writing | ################################################## | 100% 0.08s avrdude: 444 bytes of flash written avrdude: verifying flash memory against .pio/build/uno/firmware.hex: avrdude: load data flash data from input file .pio/build/uno/firmware.hex: avrdude: input file .pio/build/uno/firmware.hex contains 444 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 0.07s avrdude: verifying ... avrdude: 444 bytes of flash verified avrdude: safemode: Fuses OK (E:00, H:00, L:00) avrdude done. Thank you.
================================================ [SUCCESS] Took 2.51 seconds
This got me nothing on the serial monitor. Screenshot from Coolterm:
What can I do about it?
Thanks!!
