I’ve been trying to step through the build process after shifting my dev machine back to Linux and facing a rather odd issue with PIO failing when building an ESP32 project without giving any real information as to why. I enabled a few debug options directly in SCons and was able to see the raw CXX command line just prior to execution but not the actual command that was executed (unfortunately).
Below is the complete “verbose” output, any ideas?
mdunston@studio ~/trains/ESP32CommandStation $ pio run -e pcb_oled_sh1106 -v
Processing pcb_oled_sh1106 (build_unflags: -std=gnu++11; build_flags: -std=c++14, -g3, -DESP32_WIFIMGR_SOCKETPARAMS_LOG_LEVEL=VERBOSE, -DESP32_WIFIMGR_MDNS_LOOKUP_LOG_LEVEL=VERBOSE, -D_GLIBCXX_USE_C99, -DLOCKED_LOGGING, -DOPENMRN_EXCLUDE_REBOOT_IMPL, -DOPENMRN_EXCLUDE_FREE_HEAP_IMPL, -DPROJECT_NAME="\"ESP32 Command Station\"", -DPROJECT_VER="\"1.5.0\"", -DESP32CS_CDI_VERSION=0x0150, -DESP32CS_EXTERNAL_CONFIGURATION=true, -DENABLE_OUTPUTS=false, -DENABLE_SENSORS=false, -DSSID_NAME="\"esp32cs\"", -DSSID_PASSWORD="\"\"", -DWIFI_ENABLE_SOFT_AP_ONLY=true, -DOPS_ENABLE_PIN=17, -DOPS_THERMAL_PIN=0, -DOPS_CURRENT_SENSE_ADC=ADC1_CHANNEL_5, -DOPS_HBRIDGE_TYPE=LMD18200, -DOPS_SIGNAL_PIN=5, -DOPS_PREAMBLE_BITS=16, -DRAILCOM_BRAKE_ENABLE_PIN=25, -DRAILCOM_ENABLE_PIN=26, -DRAILCOM_SHORT_PIN=27, -DRAILCOM_UART=2, -DRAILCOM_UART_RX_PIN=36, -DPROG_ENABLE_PIN=18, -DPROG_CURRENT_SENSE_ADC=ADC1_CHANNEL_6, -DPROG_HBRIDGE_TYPE=L298, -DPROG_SIGNAL_PIN=19, -DPROG_PREAMBLE_BITS=22, -DLCC_CAN_RX_PIN=35, -DLCC_CAN_TX_PIN=32, -DINFO_SCREEN_SDA_PIN=23, -DINFO_SCREEN_SCL_PIN=21, -DSTATUS_LED_DATA_PIN=22, -DSTATUS_LED_ENABLED=CONSTANT_TRUE, -DSTATUS_LED_COLOR_ORDER=RGB, -DSTATUS_LED_TYPE=APA106, -DINFO_SCREEN_OLED=true, -DINFO_SCREEN_OLED_CHIPSET=SH1106, -DINFO_SCREEN_OLED_I2C_ADDRESS=0x3C, -DINFO_SCREEN_OLED_VERTICAL_FLIP=false; extra_scripts: utils/pio_http_headers.py; platform: espressif32; board: esp32dev; framework: espidf, arduino; lib_compat_mode: strict; monitor_speed: 115200; board_build.partitions: ESP32CS-partitions.csv; build_type: release)
PLATFORM: Espressif 32 1.11.1 > Espressif ESP32 Dev Module
- framework-arduinoespressif32 2.10004.191002 (1.0.4)
- framework-espidf 3.30300.190916 (3.3.0)
LDF Modes: Finder ~ chain, Compatibility ~ strict
Found 34 compatible libraries
|-- <OpenMRNLite> 0.1.1 (/home/mdunston/trains/ESP32CommandStation/lib/OpenMRNLite)
|-- <LCCTrainSearchProtocol> (/home/mdunston/trains/ESP32CommandStation/lib/LCCTrainSearchProtocol)
|-- <LiquidCrystal_PCF8574> 1.2.0 (/home/mdunston/trains/ESP32CommandStation/lib/LiquidCrystal_PCF8574)
| |-- <Wire> 1.0.1 (/home/mdunston/.platformio/packages/framework-arduinoespressif32/libraries/Wire)
|-- <ESP8266_SSD1306> 4.0.0 (/home/mdunston/trains/ESP32CommandStation/lib/ESP8266_SSD1306)
|-- <LocoNet2> 2.0.1 (/home/mdunston/trains/ESP32CommandStation/lib/LocoNet2)
|-- <nlohmann_json> 3.7.3 (/home/mdunston/trains/ESP32CommandStation/lib/nlohmann_json)
|-- <NeoNextion> 2.2.1 (/home/mdunston/trains/ESP32CommandStation/lib/NeoNextion)
|-- <NeoPixelBus> 2.5.0 (/home/mdunston/trains/ESP32CommandStation/lib/NeoPixelBus)
================================================================================================================================================= [FAILED] Took 13.75 seconds =================================================================================================================================================
Environment Status Duration
esp32 IGNORED
pcb IGNORED
pcb_oled_sh1106 FAILED 00:00:13.754
pcb_oled_ssd1306 IGNORED
pcb_lcd_20x4 IGNORED
pcb_lcd_16x2 IGNORED
============================================================================================================================================ 1 failed, 0 succeeded in 00:00:13.754 ============================================================================================================================================
Note, this is only failing for ESP32 builds. I have tested another project that uses an AVR chip and it compiles without issues.
