Hello !
I haven’t used PlatformIO IDE in about 2 months and now I can’t use terminal commands because apparently they do not exist.
Nothing changed on this PC because I haven’t opened it since the beginning of March. VSC is still running on an old version (1.42.1).
I am trying to upload files into an ESP32 but running pio run -t uploadfs
returns Command 'pio' not found, but there are 15 similar ones.
And running platformio update
returns platformio: command not found
Also, I can’t upload code to an ESP because there is a missing library in a finished project. I have finished this projects months ago and it worked wonders. I have made no alteration to it, yet I get:
.pio/libdeps/esp32doit-devkit-v1/Adafruit BusIO_ID6214/Adafruit_I2CDevice.h:1:18: fatal error: Wire.h: No such file or directory
I think that something happened with PIO which is messing with the pathing of everything.
I have never had this problem before.
I have uninstalled and installed PIO extensions and the result is the same.
I have deleted .vscode and .pio folders from the respective project and then closed and re-opened VSC, but with no luck.
What do you think happened ?
EDIT 1:
I have added Wire
to the lib_deps
inside platformio.ini to try and continue working with the project, but now I have other “missing” headers. They weren’t missing before. This is getting really frustrating. All the headers are there as this is a working and implemented project but all of a sudden PIO decided to screw it all up.
