I’ve been having an issue where my Processing (PDE) files get their grammar changes to C++.
The packages I have installed for Processing are, Processing, Processing-Autocomplete, and Processing Language.
By disabling and enabling different packages I’m fairly confident Platformio is the cluprit.
I can provide more info on what packages I am using, but is there anywhere in Platformio’s config’s that would be associated with PDE files?
Here is my post in the Atom forum’s regarding the topic:
We are archiving Atom and all projects under the Atom organization for an official sunset on December 15, 2022.
Est. reading time: 3 minutes
thank you.
will it break anything if i delete PDE out of those lines?
also just curious why Platformio supports PDE files? what functionality would i be missing that Platformio provides for PDE support?
thank you.
In this case, C/C++ code linter, code completion, and syntax highlighting will not work
PDE is an obsolete format of Arduino IDE compatible files. PlatformIO Build System converts these files to valid C++ source files before building.
If you don’t use PDE for PlatformIO, then you can remove “pde” from these lines above.
Personally I’m not a big fan of platformio programmatically overriding the grammars. Why doesn’t platformio add language-arduino as a dependency? language-arduino inherits from the C++ grammar and adds additional arduino support.
Zh0nd
September 14, 2018, 8:10am
#8
Arduino syntax is supported with PlatformIO in VSCode ?
If you mean code highlighting for INO files, yes, it supports!
