Hello
I’m new with platform io and i try to use on Clion IDE.
When I try to compile my projet, that not working and i get this error message
====================[ Build | Debug | az-delivery-devkit-v4 ]=================== C:\Users\paulp\AppData\Local\JetBrains\Toolbox\apps\CLion\ch-0\201.6668.126\bin\cmake\win\bin\cmake.exe --build C:\Users\paulp\CLionProjects\az\cmake-build-az-delivery-devkit-v4 --target Debug -- -j 8 Processing az-delivery-devkit-v4 (platform: espressif32; board: az-delivery-devkit-v4; framework: arduino) ------------------------------------------------------------------------------- Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/az-delivery-devkit-v4.html PLATFORM: Espressif 32 1.12.0 > AZ-Delivery ESP-32 Dev Kit C V4 HARDWARE: ESP32 240MHz, 520KB RAM, 16MB Flash DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa) PACKAGES: - framework-arduinoespressif32 3.10004.200129 (1.0.4) - tool-esptoolpy 1.20600.0 (2.6.0) - toolchain-xtensa32 2.50200.80 (5.2.0) LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf LDF Modes: Finder ~ chain, Compatibility ~ soft Found 29 compatible libraries Scanning dependencies... No dependencies Building in debug mode Compiling .pio\build\az-delivery-devkit-v4\src\main.c.o Linking .pio\build\az-delivery-devkit-v4\firmware.elf .pio\build\az-delivery-devkit-v4\libFrameworkArduino.a(main.cpp.o):(.literal._Z8loopTaskPv+0x4): undefined reference to `setup()' .pio\build\az-delivery-devkit-v4\libFrameworkArduino.a(main.cpp.o):(.literal._Z8loopTaskPv+0x8): undefined reference to `loop()' .pio\build\az-delivery-devkit-v4\libFrameworkArduino.a(main.cpp.o): In function `loopTask(void*)': C:\Users\paulp\.platformio\packages\framework-arduinoespressif32\cores\esp32/main.cpp:14: undefined reference to `setup()' C:\Users\paulp\.platformio\packages\framework-arduinoespressif32\cores\esp32/main.cpp:17: undefined reference to `loop()' collect2.exe: error: ld returned 1 exit status *** [.pio\build\az-delivery-devkit-v4\firmware.elf] Error 1 ========================= [FAILED] Took 6.78 seconds ========================= mingw32-make.exe[3]: *** [CMakeFiles/Debug] Error 1 mingw32-make.exe[2]: *** [CMakeFiles/Debug.dir/all] Error 2 mingw32-make.exe[1]: *** [CMakeFiles/Debug.dir/rule] Error 2 CMakeFiles\Debug.dir\build.make:56: recipe for target 'CMakeFiles/Debug' failed CMakeFiles\Makefile2:105: recipe for target 'CMakeFiles/Debug.dir/all' failed CMakeFiles\Makefile2:112: recipe for target 'CMakeFiles/Debug.dir/rule' failed Makefile:130: recipe for target 'Debug' failed mingw32-make.exe: *** [Debug] Error 2
i use MinGW and Clion 2020.1
remarq. if I use Clion i use VSCode. PlatformIO work fine
Thank you
