Suddenly getting this error with marlin 2.0 builds ??
Processing LPC1768 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.3.zip; board: nxp_lpc1768; framework: arduino)
In file included from buildroot/share/PlatformIO/scripts/common-dependencies.h:63:
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1639:1: error: user-defined literal in preprocessor expression
1639 | #if _HAS_STOP(X,MIN)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1642:1: error: user-defined literal in preprocessor expression
1642 | #if _HAS_STOP(X,MAX)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1645:1: error: user-defined literal in preprocessor expression
1645 | #if _HAS_STOP(Y,MIN)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1648:1: error: user-defined literal in preprocessor expression
1648 | #if _HAS_STOP(Y,MAX)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1651:1: error: user-defined literal in preprocessor expression
1651 | #if _HAS_STOP(Z,MIN)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1654:1: error: user-defined literal in preprocessor expression
1654 | #if _HAS_STOP(Z,MAX)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1657:1: error: user-defined literal in preprocessor expression
1657 | #if _HAS_STOP(X,STOP)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1660:1: error: user-defined literal in preprocessor expression
1660 | #if _HAS_STOP(Y,STOP)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1663:1: error: user-defined literal in preprocessor expression
1663 | #if _HAS_STOP(Z,STOP)
buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/Conditionals_post.h:1696:1: error: user-defined literal in preprocessor expression
1696 | #if HAS_CUSTOM_PROBE_PIN && PIN_EXISTS(Z_MIN_PROBE)
CalledProcessError: Command 'arm-none-eabi-g++.exe -D__MARLIN_FIRMWARE__ -DU8G_HAL_LINKS -D__MARLIN_PREBUILD__ -w -dM -E -x c++ buildroot/share/PlatformIO/scripts/common-dependencies.h' returned non-zero exit status 1.:
File "C:\users\webbe\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 167:
env.SConscript(item, exports="env")
File "C:\Users\webbe\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 598:
File "C:\Users\webbe\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 287:
File "E:\Google Drev\3D Print info og id�er\DADSON 3D Printer Project\DADSON_101020_Marlin-2.0.6\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 280:
apply_features_config()
File "E:\Google Drev\3D Print info og id�er\DADSON 3D Printer Project\DADSON_101020_Marlin-2.0.6\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 112:
if not env.MarlinFeatureIsEnabled(feature):
File "C:\Users\webbe\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 219:
File "E:\Google Drev\3D Print info og id�er\DADSON 3D Printer Project\DADSON_101020_Marlin-2.0.6\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 256:
load_marlin_features()
File "E:\Google Drev\3D Print info og id�er\DADSON 3D Printer Project\DADSON_101020_Marlin-2.0.6\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 244:
define_list = subprocess.check_output(cmd, shell=True).splitlines()
File "C:\Users\webbe\.platformio\python3\lib\subprocess.py", line 411:
**kwargs).stdout
File "C:\Users\webbe\.platformio\python3\lib\subprocess.py", line 512:
output=stdout, stderr=stderr)
========================== [FAILED] Took 0.59 seconds ==========================
