Hi, I’m new here and a beginner with ESP32, Linux and embedded systems. So I apologise if I’m asking really dumb questions.
I’m using a Raspberry Pi 4 with the latest 32 bit operating system. I’ve successfully installed VS Studio code and Platform IO. Using the Project Wizard to create my first project using the Espressive IOT Development Framework fails.
To help me diagnose the problem I’ve tried to copy the text in the results pop up window which tells me it has failed. I can’t find a way to do this. There is a lot of text. It seems to be replicated in my Documents folder in a file called Platform_io_error. However this also has a lot of HTML like text formatting characters which neither of my editors will ignore. I don’t really want to spend time removing them manually which is why I’m asking what markup format is used. Then I can find an appropriate editor.
For what its worth the problem seems to be a failure to load the liblto.plugin.so plugin.
Thanks, and stay safe,
Steve
