Yes I have an M1 based computer.
pio system info output:
> pio system info
PlatformIO Core 5.1.0
Python 3.8.4-final.0
System Type darwin_x86_64
Platform macOS-10.16
File System Encoding utf-8
Locale Encoding UTF-8
PlatformIO Core Directory ~/.platformio
PlatformIO Core Executable ~/.platformio/penv/bin/platformio
Python Executable ~/.platformio/penv/bin/python
Global Libraries 0
Development Platforms 2
Tools & Toolchains 11
PlatformIO.ini:
[env:teensy31]
platform = teensy
board = teensy31
lib_deps = adafruit/Adafruit MQTT Library @ ^2.1.0,
Output when compiling:
Executing task in folder ESP32_TEST: pio run <
Processing teensy31 (platform: teensy; board: teensy31; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy31.html
PLATFORM: Teensy (4.12.0) > Teensy 3.1 / 3.2
HARDWARE: MK20DX256 72MHz, 64KB RAM, 256KB Flash
DEBUG: Current (jlink) External (jlink)
- framework-arduinoteensy 1.153.0 (1.53)
- toolchain-gccarmnoneeabi 1.50401.190816 (5.4.1)
ValueError: Invalid simple block '':
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/builder/main.py", line 177:
File "~/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Script/SConscript.py", line 591:
File "~/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Script/SConscript.py", line 280:
File "~/.platformio/platforms/teensy/builder/main.py", line 144:
File "~/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Util.py", line 658:
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/builder/tools/platformio.py", line 62:
env.ProcessProjectDeps()
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/builder/tools/platformio.py", line 140:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/builder/tools/piolib.py", line 1062:
project.install_dependencies()
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/builder/tools/piolib.py", line 886:
if lm.get_package(spec):
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/package/manager/base.py", line 234:
spec = self.ensure_spec(spec)
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/package/manager/base.py", line 102:
return spec if isinstance(spec, PackageSpec) else PackageSpec(spec)
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/package/meta.py", line 124:
self._parse(self.raw)
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/package/meta.py", line 227:
raw = parser(raw)
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/package/meta.py", line 250:
self.requirements = tokens[1].strip()
File "~/.platformio/penv/lib/python3.8/site-packages/platformio/package/meta.py", line 167:
else semantic_version.SimpleSpec(str(value))
File "~/.platformio/penv/lib/python3.8/site-packages/semantic_version/base.py", line 618:
self.clause = self._parse_to_clause(expression)
File "~/.platformio/penv/lib/python3.8/site-packages/semantic_version/base.py", line 1014:
return cls.Parser.parse(expression)
File "~/.platformio/penv/lib/python3.8/site-packages/semantic_version/base.py", line 1034:
raise ValueError("Invalid simple block %r" % block)
