I have a MikroE board with STM32f4 and I’m trying to setup PlaftormIO to work with it.
There is a open-source tool developed to upload code to this board, and it works: GitHub - thotypous/mikroe-uhb: USB HID Bootloader programming tool for devices manufactured by MikroElektronika
I have already setted up the board json file, but I’m having problems to generate the .hex to upload. This board/uploader needs a .hex, not a .elf.
This is the json board I have:
“build”: {
“core”: “stm32”,
“cpu”: “cortex-m4”,
“extra_flags”: “-DSTM32F4 -DSTM32F407xx -DSTM32F40_41xxx”,
“f_cpu”: “168000000L”,
“ldscript”: “stm32f405x6.ld”,
“mcu”: “stm32f407vgt6”,
“variant”: “stm32f407xx”
“frameworks”: [
“libopencm3”,
“cmsis”
“name”: “Mikromedia for STM32 M4”,
“upload”: {
“maximum_ram_size”: 131072,
“maximum_size”: 1048576,
“protocol”: “mikroe-uhb”
“url”: “MikroElektronika”,
“vendor”: “mikromedia for STM32 M4 - ARM Cortex-M4 Development Board”
I tried to modify ststm32/builder/main.py to check for the upload protocol “mikroe-uhb” and build the .hex instead of a .elf but I get an error:
*** Multiple ways to build the same target were specified for: /home/h/projects/STM32F4_test/.pioenvs/mikroe/firmware.hex (from [‘/home/h/projects/STM32F4_test/.pioenvs/mikroe/src/main.o’] and from [‘/home/h/projects/STM32F4_test/.pioenvs/mikroe/firmware.hex’])
File “/home/h/.platformio/platforms/ststm32/builder/main.py”, line 174, in
This is the file:
# Copyright 2014-present PlatformIO <contact@platformio.org>
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
from os.path import basename, isfile, join
from SCons.Script import (COMMAND_LINE_TARGETS, AlwaysBuild, Builder, Default,
DefaultEnvironment)
env = DefaultEnvironment()
env.Replace(
AR="arm-none-eabi-ar",
AS="arm-none-eabi-as",
CC="arm-none-eabi-gcc",
CXX="arm-none-eabi-g++",
OBJCOPY="arm-none-eabi-objcopy",
RANLIB="arm-none-eabi-ranlib",
SIZETOOL="arm-none-eabi-size",
ARFLAGS=["rcs"],
ASFLAGS=["-x", "assembler-with-cpp"],
CCFLAGS=[
"-g", # include debugging info (so errors include line numbers)
"-Os", # optimize for size
"-ffunction-sections", # place each function in its own section
"-fdata-sections",
"-Wall",
"-mthumb",
"-nostdlib"
CXXFLAGS=[
"-fno-rtti",
"-fno-exceptions"
CPPDEFINES=[
("F_CPU", "$BOARD_F_CPU")
LINKFLAGS=[
"-Os",
"-Wl,--gc-sections,--relax",
"-mthumb",
"-nostartfiles",
"-nostdlib"
LIBS=["c", "gcc", "m", "stdc++", "nosys"],
UPLOADER="st-flash",
UPLOADERFLAGS=[
"write", # write in flash
"$SOURCES", # firmware path to flash
"0x08000000" # flash start adress
UPLOADCMD='$UPLOADER $UPLOADERFLAGS',
SIZEPRINTCMD='$SIZETOOL -B -d $SOURCES',
PROGNAME="firmware",
PROGSUFFIX=".elf"
if "BOARD" in env:
env.Append(
CCFLAGS=[
"-mcpu=%s" % env.BoardConfig().get("build.cpu")
CPPDEFINES=[
env.BoardConfig().get("build.variant", "").upper()
LINKFLAGS=[
env.Append(
ASFLAGS=env.get("CCFLAGS", [])[:],
BUILDERS=dict(
ElfToBin=Builder(
action=env.VerboseAction(" ".join([
"$OBJCOPY",
"-O",
"binary",
"$SOURCES",
"$TARGET"
]), "Building $TARGET"),
suffix=".bin"
ElfToHex=Builder(
"$OBJCOPY",
"-O",
"ihex",
"-R",
".eeprom",
"$SOURCES",
"$TARGET"
suffix=".hex"
if env.subst("$UPLOAD_PROTOCOL") == "gdb":
if not isfile(join(env.subst("$PROJECT_DIR"), "upload.gdb")):
env.Exit(
"Error: You are using GDB as firmware uploader. "
"Please specify upload commands in upload.gdb "
"file in project directory!"
env.Replace(
UPLOADER="arm-none-eabi-gdb",
UPLOADERFLAGS=[
join("$BUILD_DIR", "firmware.elf"),
"-batch",
"-x",
join("$PROJECT_DIR", "upload.gdb")
elif env.subst("$UPLOAD_PROTOCOL") in ("serial", "dfu") \
and "arduino" in env.subst("$PIOFRAMEWORK"):
_upload_tool = "serial_upload"
_upload_flags = ["{upload.altID}", "{upload.usbID}"]
if env.subst("$UPLOAD_PROTOCOL") == "dfu":
_upload_tool = "maple_upload"
_usbids = env.BoardConfig().get("build.hwids")
_upload_flags = [env.BoardConfig().get("upload.boot_version", 2),
"%s:%s" % (_usbids[0][0][2:], _usbids[0][1][2:])]
env.Replace(
UPLOADER=_upload_tool,
UPLOADERFLAGS=["$UPLOAD_PORT"] + _upload_flags,
UPLOADCMD=(
'$UPLOADER $UPLOADERFLAGS $PROJECT_DIR/$SOURCES'))
############### I changed here ##############
elif env.subst("$UPLOAD_PROTOCOL") == "mikroe-uhb":
env.Replace(
PROGSUFFIX=".hex",
UPLOADER="mikroe-uhb",
UPLOADERFLAGS=[ "-v", "$PROJECT_DIR/$SOURCES" ],
UPLOADCMD='$UPLOADER $UPLOADERFLAGS,'
# Target: Build executable and linkable firmware
target_elf = None
if "nobuild" in COMMAND_LINE_TARGETS:
target_firm = join("$BUILD_DIR", "firmware.bin")
else:
##### and here #####
if env.subst("$PROGSUFFIX") == ".hex":
target_firm = env.ElfToHex(join("$BUILD_DIR", "firmware"), target_elf) # this is the line with error
else:
target_firm = env.ElfToBin(join("$BUILD_DIR", "firmware"), target_elf)
AlwaysBuild(env.Alias("nobuild", target_firm))
target_buildprog = env.Alias("buildprog", target_firm, target_firm)
# Target: Print binary size
target_size = env.Alias(
"size", target_elf,
env.VerboseAction("$SIZEPRINTCMD", "Calculating size $SOURCE"))
AlwaysBuild(target_size)
# Target: Upload by default .bin file
if "mbed" in env.subst("$PIOFRAMEWORK") and not env.subst("$UPLOAD_PROTOCOL"):
target_upload = env.Alias(
"upload", target_firm,
[env.VerboseAction(env.AutodetectUploadPort,
"Looking for upload disk..."),
env.VerboseAction(env.UploadToDisk, "Uploading $SOURCE")])
elif "arduino" in env.subst("$PIOFRAMEWORK"):
def BeforeUpload(target, source, env):
env.AutodetectUploadPort()
env.Replace(UPLOAD_PORT=basename(env.subst("$UPLOAD_PORT")))
[env.VerboseAction(BeforeUpload,
env.VerboseAction("$UPLOADCMD", "Uploading $SOURCE")])
#elif env.subst("$UPLOAD_PROTOCOL") == "mikroe-uhb":
# print "mikroe"
else:
env.VerboseAction("$UPLOADCMD", "Uploading $SOURCE"))
AlwaysBuild(target_upload)
# Default targets
Default([target_buildprog, target_size])
Any ideas how to solve this?
I decided to not create a new platform because this board use the same STM32 as other vendors, the difference is the uploading protocol.
I still need to find out how to create the uploader tool without installing it manually.
Thank you in advance!
