I get this error, as I’m trying to debug my SMT32F103VCT6 MCU. I’m using STLink-V3. I have tried providing as much information regarding my setup in the initialization file. I have seen this error (or similar ones) are quite common, but haven’t found a solution based on other answers.
This is the complete debug log from terminal.
hla_swd
Info : DEPRECATED target event trace-config; use TPIU events {pre,post}-{enable,disable}
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 1000 kHz
Info : STLINK V3J8M3 (API v3) VID:PID 0483:374E
Info : Target voltage: 3.294055
Info : stm32f1x.cpu: Cortex-M3 r1p1 processor detected
Info : stm32f1x.cpu: target has 6 breakpoints, 4 watchpoints
Info : starting gdb server for stm32f1x.cpu on pipe
Info : device id = 0x10036414
Info : flash size = 256kbytes
0x08001b86 in ?? ()
Loading section ER_RO, size 0x12f74 lma 0x8000
.pioinit:15: Error in sourced command file:
This is the initialization file I’m using:
[env:genericSTM32F103VC]
platform = ststm32
board = genericSTM32F103VC
#framework = stm32cube ; can't use, provide custom flags
extra_scripts = SetCompilerPath.py
platform_packages = toolchain-armcc@symlink://C:\Keil_v5\ARM\ARMCC\bin
board_build.ldscript = "PCV2-SES.sct" ; previously it was GCC "src\STM32F103VCTx_FLASH.ld" (which is indirectly supported by ARM via link options)
-Isrc/Core/Inc
-Isrc/Drivers/STM32F1xx_HAL_Driver/Inc
-Isrc/Drivers/CMSIS/Device/ST/STM32F1xx/Include
-Isrc/Drivers/CMSIS/Include
upload_protocol = stlink
debug_tool = stlink
#upload_command = ${platformio.packages_dir}/tool-stlink/st-flash write $SOURCE 0x8000000
board_build.mcu = stm32f103vct6
