When I try to build from the command-line using pio
directly, the process gets interrupted because .pioenvs
is created with dr-x-------
(500) permissions which is read-only. If I chmod -r 755 .pioenvs
it will then then apply the same read-only permissions on the first sub-folder created. After each error I do the chmod
command and it finally succeeds in the build.
Is there some known reason or setting that causes this folder and its children to be created read-only?
