Okay so that tells me that a bootloader burned previously onto your ATMega1284p chip has responded but somehow writing didn’t succeed? Just to be sure when using melzi
instead of melzi_optiboot
you do not get this message?
I used Melzi build then Melzi Upload
Okay so for safety can you try it with melzi_optiboot
too.
running upload optiboot this is what I get
Linking .pioenvs\melzi_optiboot\firmware.elf
Marlin\planner.cpp: In function ‘_set_position_mm’:
Marlin\planner.cpp:2697:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See http://gcc.gnu.org/bugs.html for instructions.
lto-wrapper.exe: fatal error: avr-g++ returned 1 exit status
compilation terminated.
c:/users/theca/.platformio/packages/toolchain-atmelavr/bin/…/lib/gcc/avr/5.4.0/…/…/…/…/avr/bin/ld.exe: error: lto-wrapper failed
*** [.pioenvs\melzi_optiboot\firmware.elf] Error 1
[ERROR] Took 65.58 seconds
[SUMMARY]
Environment megaatmega2560 [SKIP]
Environment megaatmega1280 [SKIP]
Environment at90USB1286_CDC [SKIP]
Environment at90USB1286_DFU [SKIP]
Environment melzi [SKIP]
Environment melzi_optiboot [ERROR]
Environment rambo [SKIP]
Environment sanguino_atmega644p [SKIP]
Environment sanguino_atmega1284p [SKIP]
Environment teensy20 [SKIP]
Board name: BOARD_MELZI
Build type: upload
Environment used: melzi_optiboot
Do a project clean (Ctrl+Shift+P+“Clean” or pio run -t clean
) and retry
Ok did that and re ran upload optiboot and here are the results
Building .pioenvs\melzi_optiboot\firmware.hex
Checking size .pioenvs\melzi_optiboot\firmware.elf
Memory Usage → Redirecting...
DATA: [== ] 15.3% (used 2513 bytes from 16384 bytes)
PROGRAM: [==== ] 41.6% (used 54112 bytes from 130048 bytes)
Configuring upload protocol…
AVAILABLE: arduino
Looking for upload port…
Auto-detected: COM3
Uploading .pioenvs\melzi_optiboot\firmware.hex
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x68
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6f
avrdude done. Thank you.
*** [upload] Error 1
[ERROR] Took 74.22 seconds
[SUMMARY]
[ERROR] Took 74.24 seconds
Build type: upload
Ok that confirms that actually the melzi
target is the correct one and the bootloader answrs to this. Can you clean the project again and retry with the melzi
environment a few times?
Not 100% on what you mean. Can you dumb it down 1 or 2 notches? Not all the way down.
Also will I get limited today as well like yesterday? that sucked. I even paid and signed up for the year thinking it would allow me to continue
And I really appreciate all you have done so far.
You tried the melzi_optiboot
environment which has the bootloader baudrate at 115200 (refer here). You did not get a “Device signature = 0x1e9705” message. You tried the melzi
environment with 57600 bootloader baud => the device reponds with the device signature and some readout happens => melzi
should have the correct bootloader settings => retry with env_default = melzi
again
If the spam-bot picks something up I can manually approve the posts since I’m a mod.
ok so If I understood you. I went into my platformio.ino and change env_default from melzi_optiboot to just Melzi and ran upload melzi and the I got this
Linking .pioenvs\melzi\firmware.elf
Checking size .pioenvs\melzi\firmware.elf
Building .pioenvs\melzi\firmware.hex
AVAILABLE: arduino
Auto-detected: COM3
Uploading .pioenvs\melzi\firmware.hex
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: reading input file “.pioenvs\melzi\firmware.hex”
avrdude: writing flash (54112 bytes):
Writing | avrdude: stk500_recv(): programmer is not responding
Being able to read the device signature but not being able to write anything to it might be due to the LOCK bit being set, preventing it from being written to. (avr - Failing to write ATMega16U4 fuses with avrdude - Electrical Engineering Stack Exchange). The only thing that can change this lock is a complete chip erase cycle. This cannot be done via the USB/serial bootloader.
You can also try and read the fuses using avrdude
with the correct MCU parameters, here e.g. described for a ATMega328P, and then decode the fuse values according to your ATMega1284P’s datasheet.
I’d suggest programming it over the 6 or 10-pin ICSP header on the board (see JP17) it using an usbasp programmer (e.g. on amazon) or, equivalently flash an Arduino Uno with the Arduino as ISP sketch. Once you have either programmer connected to the board, you can then try and use the upload_protocol
and friend settings from Atmel AVR — PlatformIO latest documentation for usbASP
or Arduino as ISP
respectively in the platformio.ini
file and use the pio run -t program
“Upload using programmer” target.
ok I will try this. I have ardunio boards and jumpers to do this. I will try and be back
Ok Shoot me… I guess im getting closer… this is the error Im getting trying to upload. I know its something stupid.
Processing Melzi (framework: arduino; platform: atmelavr)
Verbose mode can be enabled via -v, --verbose
option
Please specify board
in platformio.ini
to use with ‘arduino’ framework
[ERROR] Took 1.01 seconds
[SUMMARY]
Environment Melzi [ERROR]
Environment Melzi_optiboot [SKIP]
Build type: program
Environment used: Melzi
What is your exact platformio.ini
now (please format as code), what hardware do you have connected in what way to the melzi board and what command to you use for uploading?
I have a uno card plugged in via usb
Melzi board pwer is plugged into pwr supply
I have the 4 jumper wires from uno to melzi board
I was using upload with programmer command
# Marlin Firmware
# PlatformIO Configuration File
# For detailed documentation with EXAMPLES:
# http://docs.platformio.org/en/latest/projectconf.html
# Automatic targets - enable auto-uploading
# targets = upload
# By default platformio build will abort after 5 errors.
# Remove '-fmax-errors=5' from build_flags below to see all.
[platformio]
src_dir = Marlin
build_dir = .pioenvs
lib_dir = .piolib
libdeps_dir = .piolibdeps
env_default = Melzi
[common]
build_flags = -fmax-errors=5
-g
-ggdb
https://github.com/MarlinFirmware/U8glib-HAL/archive/dev.zip
LiquidCrystal_I2C@1.1.2
TMC2130Stepper
https://github.com/teemuatlut/TMC2208Stepper/archive/v0.1.1.zip
Adafruit NeoPixel@1.1.3
https://github.com/lincomatic/LiquidTWI2/archive/30aa480.zip
https://github.com/ameyer/Arduino-L6470/archive/master.zip
https://github.com/trinamic/TMC26XStepper/archive/c1921b4.zip
# Unique Core Architectures #
# Add a new "env" below if no #
# entry has values suitable to #
# build for a given board. #
# ATmega2560
[env:megaatmega2560]
board = megaatmega2560
build_flags = ${common.build_flags}
board_build.f_cpu = 16000000L
lib_deps = ${common.lib_deps}
monitor_speed = 250000
# ATmega1280
[env:megaatmega1280]
board = megaatmega1280
# AT90USB1286 boards using CDC bootloader
# - BRAINWAVE
# - BRAINWAVE_PRO
# - SAV_MKI
# - TEENSYLU
[env:at90USB1286_CDC]
platform = teensy
board = at90USB1286
lib_ldf_mode = deep+
extra_scripts = pre:buildroot/share/atom/create_custom_upload_command_CDC.py
# AT90USB1286 boards using DFU bootloader
# - PrintrBoard
# - PrintrBoard Rev.F
# - ? 5DPRINT ?
[env:at90USB1286_DFU]
platform = teensy
board = at90USB1286
extra_scripts = pre:buildroot/share/atom/create_custom_upload_command_DFU.py
# Melzi and clones (ATmega1284p)
[env:Melzi]
upload_protocol = stk500v1
; each flag in a new line
upload_flags =
-P$UPLOAD_COM6
-b$UPLOAD_57600
; edit these lines
upload_port = COM6
upload_speed = 57600
# Melzi and clones (Optiboot bootloader)
[env:Melzi_optiboot]
board = sanguino_atmega1284p
upload_speed = 115200
# RAMBo
[env:rambo]
board = reprap_rambo
# Sanguinololu (ATmega644p)
[env:sanguino_atmega644p]
board = sanguino_atmega644p
# Sanguinololu (ATmega1284p)
[env:sanguino_atmega1284p]
# Teensy++ 2.0
[env:teensy20]
platform = teensy
board = teensy20pp
#board_build.f_cpu = 20000000L ; Bug in Arduino framework disallows boards running at 20Mhz
Use the following Melzi
environment, you seem to have deleted some important fields.
[env:Melzi]
upload_flags =
-P$UPLOAD_PORT
-b$UPLOAD_SPEED
upload_port = COM6
upload_speed = 19200
This expects the Arduino (with previously flashed Arduino as ISP sketch) on COM6.
I got excited for a minute. It looked very promising.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
*** [program] Error 1
[ERROR] Took 69.72 seconds
Check all power, SPI + reset connections. (common GND, MISO, MOSI, SCLK, RESET). You must have 5 wires. Double check the pin connections to the Uno and to the target’s ICSP header. E.g., are you able to measure +5V (=Vcc) and GND at the expected pins on that header? (refer Arduino as ISP).
Is the target powered powered separately and not from the Uno?
YAHOOOOOO… It is great to see that green success pop up… I had everything right except for the ground pin between the uno and melzi. I figured I didn’t need it due to the fact I wasn’t powering the melzi pord with the 5v pin. I was using a 12v pwr supply to the main board and the uno was from the pc.
time to plug it all back in and see what happens.
ill keep you posted. thanks for all your help
avrdude: verifying …
avrdude: 54110 bytes of flash verified
[SUCCESS] Took 101.52 seconds
[SUMMARY]
Environment Melzi [SUCCESS]
Build type: program
That look very good
The people who gave you that firmware hopefully gave you a version which has the correct pin mappins for your motors and stuff for that board etc? Or is it custom for your board and you need to change that? (I’m no expert on 3D printer setup here, but if something doesn’t work, it may be because of wrong pins in the firmware)
Ah, and it might also be intersting to see whether one can now flash the Melzi board over the USB serial bootloader with the original platformio.ini
configuration…
