The platformio.ini
in the “dev” branch actually seems more sensible than that in the stable / main branch, since it fixes the version of the Espressif8266 platform. Stable uses bleeding edge (antipattern…)
Thus it seems like issues with the same root cause as in https://github.com/esprfid/esp-rfid/issues/354.
When I do a git checkout dev
in the project folder to switch to the branch, and then Build / pio run
PLATFORM: Espressif 8266 (2.3.2) > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 160MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 2.20603.191216 (2.6.3)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
RAM: [===== ] 51.5% (used 42192 bytes from 81920 bytes)
Flash: [====== ] 63.8% (used 666472 bytes from 1044464 bytes)
Creating BIN file ".pio\build\generic\firmware.bin" using ".pio\build\generic\firmware.elf"
after_build(["buildprog"], [".pio\build\generic\firmware.bin"])
============================================= [SUCCESS] Took 77.30 seconds =============================================
all is fine.
Switching back to stable
branch gives
PLATFORM: Espressif 8266 (2.6.2+sha.468a625) > Espressif ESP8266 ESP-12E
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptoolpy 1.30000.201119 (3.0.0)
RAM: [===== ] 50.7% (used 41540 bytes from 81920 bytes)
Flash: [====== ] 63.1% (used 658748 bytes from 1044464 bytes)
Creating BIN file ".pio\build\generic\firmware.bin" using "C:\Users\Max\.platformio\packages\framework-arduinoespressif8266\bootloaders\eboot\eboot.elf" and ".pio\build\generic\firmware.elf"
============== [SUCCESS] Took 36.57 seconds ==============
… also a successfull compilation!
This version is not found / correct in any of the two compilations.
I’d suggest you
rm -rf ~/.platformio/packages/framework-arduinoespressif8266*
(to get rid of all versions of the Arduino-ESP8266 framework, they’ll be automatically reinstalled later)
pio upgrade --dev
to get the latest PIO core version
- try and build the
stable
branch again
- try and build the
dev
branch
