I am receiving the following error when trying to use the Platform IO debugger. This previously worked a few months ago.
I am using the Sodaq Explorer board with Arduino framework.
Reading symbols from e:\Users\Brendan\My Documents\GitHub\FallDetection_V2.pioenvs\sodaq_one\firmware.elf…
done.
PlatformIO Unified Debugger > Redirecting...
GNU MCU Eclipse 32-bits Open On-Chip Debugger 0.10.0+dev-00392-gbe9ef0b0 (2018-01-12-10:20)
Licensed under GNU GPL v2
For bug reports, read OpenOCD: Bug Reporting
little
Info : auto-selecting first available session transport “swd”. To override use ‘transport select ’.
none separate
adapter speed: 400 kHz
cortex_m reset_config sysresetreq
Info : tcl server disabled
Any Ideas how I can fix this? I would really appreciate some help.
i was using a JTAG EDU, but now I am using a Atmel SAM ICE. Neither are working.
The error message from the SAM ICE is:
little
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
none separate
Info : telnet server disabled
Error: unable to open CMSIS-DAP device 0x3eb:0x2141
.pioinit:12: Error in sourced command file:
Remote communication error. Target disconnected.: No error.
Is it possible to add selection of display method for watched expressions?
It’s really nearly useless to see a decimal value of an MCU register. I’d love to be able to see it in hex without using an external calculator/converter. Being able to divide any watched value into binary groups would be even greater. But at least please add hex!
This is a problem os VSCode. We don’t have API for this functionality See
Nevertheless, could you try
you can use postfixes in Watch window to show numbers in hex format, for example:
Variable,h - show value of Variable in hex
Variable,o - show value as base 8 number
I faced the same issue when I use openocd and gdb in VSCode with platformio plugin, but I found it is really slow, I waited about 1 minute to see it enter to first breakpoint, and when I tried to step it, 30 seconds wait is needed. And then I switched to eclipse ide, but I can smoothly debug it. I am using the same toolchain and openocd, what can be related to this issue?
I’m a fresh new contributor to this community. I’m re-opening a very old topic “how to debug with GDB on ESP8266 with VSC/PIO” with the Unified Debugger and GDBstub. (eg no HW debugger)
After a few research, I made a specific program called gdbpipe to fix the VSC code issue (eg VSC insert a break-point on a ‘main’ function which does not exist on Arduino , leading GDB to exit right away).
See HERE. It allows to have visual debugging with 8266 program on VSC.
Hope it may save time to someone else on the community as he did on my side.
