Hello everyone,
Today I updated vscode and pio.
After the update I tried to build my project but it won’t run the build script :
Executing task in folder ENI-Logger: pio run <
Processing disco_f746ng (platform: ststm32; board: disco_f746ng; framework: mbed)
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/disco_f746ng.html
PLATFORM: ST STM32 (10.0.1) > ST 32F746GDISCOVERY
HARDWARE: STM32F746NGH6 216MHz, 320KB RAM, 1MB Flash
- framework-mbed 6.60200.200722 (6.2.0)
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
AttributeError: type object ‘array.array’ has no attribute ‘tostring’:
File “/home/mathieu-ledimna/.platformio/penv/lib/python3.9/site-packages/platformio/builder/main.py”, line 170:
File “/home/mathieu-ledimna/.platformio/packages/tool-scons/scons-local-4.0.1/SCons/Script/SConscript.py”, line 598:
File “/home/mathieu-ledimna/.platformio/packages/tool-scons/scons-local-4.0.1/SCons/Script/SConscript.py”, line 287:
exec(compile(scriptdata, scriptname, ‘exec’), call_stack[-1].globals)
File “/home/mathieu-ledimna/.platformio/platforms/ststm32/builder/main.py”, line 99:
File “/home/mathieu-ledimna/.platformio/packages/tool-scons/scons-local-4.0.1/SCons/Environment.py”, line 219:
File “/home/mathieu-ledimna/.platformio/penv/lib/python3.9/site-packages/platformio/builder/tools/platformio.py”, line 61:
env.ProcessProgramDeps()
File “/home/mathieu-ledimna/.platformio/penv/lib/python3.9/site-packages/platformio/builder/tools/platformio.py”, line 127:
env.BuildFrameworks(env.get(“PIOFRAMEWORK”))
File “/home/mathieu-ledimna/.platformio/penv/lib/python3.9/site-packages/platformio/builder/tools/platformio.py”, line 342:
SConscript(env.GetFrameworkScript(f), exports=“env”)
File “/home/mathieu-ledimna/.platformio/packages/tool-scons/scons-local-4.0.1/SCons/Script/SConscript.py”, line 661:
return method(*args, **kw)
File “/home/mathieu-ledimna/.platformio/platforms/ststm32/builder/frameworks/mbed.py”, line 35:
SConscript(
File “/home/mathieu-ledimna/.platformio/packages/framework-mbed/platformio/platformio-build.py”, line 43:
from pio_mbed_adapter import PlatformioMbedAdapter
File “/home/mathieu-ledimna/.platformio/packages/framework-mbed/platformio/pio_mbed_adapter.py”, line 23:
from tools.build_api import prepare_toolchain, UPDATE_WHITELIST
File “/home/mathieu-ledimna/.platformio/packages/framework-mbed/tools/build_api.py”, line 37:
from .utils import (mkdir, run_cmd, run_cmd_ext, NotSupportedException,
File “/home/mathieu-ledimna/.platformio/packages/framework-mbed/tools/utils.py”, line 33:
from intelhex import IntelHex
File “/home/mathieu-ledimna/.platformio/packages/framework-mbed/platformio/package_deps/py3/intelhex/init.py”, line 44:
from intelhex.compat import (
File “/home/mathieu-ledimna/.platformio/packages/framework-mbed/platformio/package_deps/py3/intelhex/compat.py”, line 60:
array_tobytes = getattr(array.array, “tobytes”, array.array.tostring)
================================================= [FAILED] Took 0.39 seconds =================================================
The terminal process “pio ‘run’” terminated with exit code: 1.
Has anyone got this type of error ?
