I was running my pio remote for some time and all was well. Now after running command “pio remote agent run” the installation of platformio/contrib-pysite @ ~2.37.0 starts and Tool Manager: contrib-pysite @ 2.37.191020 has been installed!
and suddenly all goes wrong:
My raspian version VERSION=“10 (buster)”
My PIO version is 5.0.1 and I use only the core CLI installation.
I did a uninstall “pip uninstall platformio” and reinstall python3 -c “$(curl -fsSL https://raw.githubusercontent.com/platformio/platformio/develop/scripts/get-platformio.py)”
And no change.
There is lots of steps going on but here is the part where it happens:
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /home/pi/.platformio/penv/bin/python /home/pi/.platformio/penv/lib/python3.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-hhys1cme/overlay --no-warn-script-location --no-binary :all: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"''
cwd: None
Complete output (84 lines):
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple, https://www.piwheels.org/simple
Collecting setuptools>=40.6.0
Using cached setuptools-50.3.0.zip (2.2 MB)
Collecting wheel
Using cached wheel-0.35.1.tar.gz (59 kB)
Collecting cffi!=1.11.3,>=1.8
Using cached cffi-1.14.2.tar.gz (470 kB)
Collecting pycparser
Using cached pycparser-2.20.tar.gz (161 kB)
Skipping wheel build for setuptools, due to binaries being disabled for it.
Skipping wheel build for wheel, due to binaries being disabled for it.
Skipping wheel build for cffi, due to binaries being disabled for it.
Skipping wheel build for pycparser, due to binaries being disabled for it.
Installing collected packages: setuptools, wheel, pycparser, cffi
Running setup.py install for setuptools: started
Running setup.py install for setuptools: finished with status 'done'
Running setup.py install for wheel: started
Running setup.py install for wheel: finished with status 'done'
Running setup.py install for pycparser: started
Running setup.py install for pycparser: finished with status 'done'
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
command: /home/pi/.platformio/penv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-_pwyfamh/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-_pwyfamh/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-d547iuo1/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-hhys1cme/overlay --compile --install-headers /tmp/pip-build-env-hhys1cme/overlay/include/site/python3.7/cffi
cwd: /tmp/pip-install-_pwyfamh/cffi/
Complete output (56 lines):
Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libffi' found
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.7
creating build/lib.linux-armv7l-3.7/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/lock.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/api.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/cparser.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/recompiler.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/verifier.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/error.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/commontypes.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/model.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/__init__.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.7/cffi
copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.7/cffi
copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.7/cffi
copying cffi/_embedding.h -> build/lib.linux-armv7l-3.7/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.7/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-armv7l-3.7
creating build/temp.linux-armv7l-3.7/c
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/home/pi/.platformio/penv/include -I/usr/include/python3.7m -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.7/c/_cffi_backend.o
c/_cffi_backend.c:15:10: fatal error: ffi.h: No such file or directory
#include <ffi.h>
compilation terminated.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /home/pi/.platformio/penv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-_pwyfamh/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-_pwyfamh/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-d547iuo1/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-hhys1cme/overlay --compile --install-headers /tmp/pip-build-env-hhys1cme/overlay/include/site/python3.7/cffi Check the logs for full command output.
ERROR: Command errored out with exit status 1: /home/pi/.platformio/penv/bin/python /home/pi/.platformio/penv/lib/python3.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-hhys1cme/overlay --no-warn-script-location --no-binary :all: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"'' Check the logs for full command output.
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/platformio/package/manager/core.py", line 88, in inject_contrib_pysite
from OpenSSL import SSL
File "/home/pi/.platformio/packages/contrib-pysite/OpenSSL/__init__.py", line 8, in <module>
File "/home/pi/.platformio/packages/contrib-pysite/OpenSSL/crypto.py", line 12, in <module>
File "/home/pi/.platformio/packages/contrib-pysite/cryptography/x509/__init__.py", line 8, in <module>
File "/home/pi/.platformio/packages/contrib-pysite/cryptography/x509/base.py", line 18, in <module>
File "/home/pi/.platformio/packages/contrib-pysite/cryptography/x509/extensions.py", line 20, in <module>
File "/home/pi/.platformio/packages/contrib-pysite/cryptography/hazmat/primitives/constant_time.py", line 11, in <module>
ImportError: /home/pi/.platformio/packages/contrib-pysite/cryptography/hazmat/bindings/_constant_time.abi3.so: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/platformio/__main__.py", line 109, in main
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/click/core.py", line 829, in __call__
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/platformio/commands/__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/click/core.py", line 1259, in invoke
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/click/core.py", line 1256, in invoke
Command.invoke(self, ctx)
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/click/core.py", line 1066, in invoke
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/click/decorators.py", line 21, in new_func
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/platformio/commands/remote/command.py", line 48, in cli
inject_contrib_pysite(verify_openssl=True)
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/platformio/package/manager/core.py", line 90, in inject_contrib_pysite
build_contrib_pysite_deps(get_core_package_dir("contrib-pysite"))
File "/home/pi/.platformio/penv/lib/python3.7/site-packages/platformio/package/manager/core.py", line 115, in build_contrib_pysite_deps
dep,
File "/usr/lib/python3.7/subprocess.py", line 347, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/home/pi/.platformio/penv/bin/python', '-m', 'pip', 'install', '--no-compile', '--no-binary', ':all:', '-t', '/home/pi/.platformio/packages/contrib-pysite', 'autobahn == 20.4.3']' returned non-zero exit status 1.
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
