I am not sure if this is a bug, or if I am doing something wrong. Anyway, this one kept me busy for the entire day.
Whatever I try, pio keeps building partitions.bin using default.csv, despite the explicit override board_build.partition in platfomio.ini
I followed these instructons:
[Custom partitions](Espressif 32 — PlatformIO latest documentation)
The platformio.config:
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
board_build.partition = mypartition.csv
upload_speed = 921600
check_skip_packages = yes
bblanchon/ArduinoJson@^6.20.0
ayushsharma82/AsyncElegantOTA@^2.2.7
rlogiacco/CircularBuffer@^1.3.3
lennarthennigs/ESP Telnet@^2.0.0
jonniezg/EWMA@^1.0.2
luisllamasbinaburo/MedianFilterLib@^1.0.0
me-no-dev/AsyncTCP@^1.1.1
https://github.com/me-no-dev/ESPAsyncWebServer.git
build_type = debug
the partitions file is in the project folder root , next to platformio.ini
Build verbose shows:
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; board_build.partition: mypartition.csv; framework: arduino; monitor_speed: 115200; monitor_filters: esp32_exception_decoder; upload_speed: 921600; check_skip_packages: True; lib_deps: bblanchon/ArduinoJson@^6.20.0, ayushsharma82/AsyncElegantOTA@^2.2.7, rlogiacco/CircularBuffer@^1.3.3, lennarthennigs/ESP Telnet@^2.0.0, jonniezg/EWMA@^1.0.2, luisllamasbinaburo/MedianFilterLib@^1.0.0, me-no-dev/AsyncTCP@^1.1.1, https://github.com/me-no-dev/ESPAsyncWebServer.git; build_type: debug)
PLATFORM: Espressif 32 (5.3.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 @ 3.20006.221224 (2.0.6)
- tool-esptoolpy @ 1.40400.0 (4.4.0)
and then further down the line:
"C:\Users\michi\.platformio\penv\Scripts\python.exe" "C:\Users\michi\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o .pio\build\esp32doit-devkit-v1\bootloader.bin C:\Users\michi\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32\bin\bootloader_dio_40m.elf
"C:\Users\michi\.platformio\penv\Scripts\python.exe" "C:\Users\michi\.platformio\packages\framework-arduinoespressif32\tools\gen_esp32part.py" -q C:\Users\michi\.platformio\packages\framework-arduinoespressif32\tools\partitions\default.csv .pio\build\esp32doit-devkit-v1\partitions.bin
esptool.py v4.4
Creating esp32 image...
Merged 1 ELF section
It still uses default.csv.
Does anyone know what I am doing wrong / or what I need to do to fix this ?
Help much appreciated !
