Which is the best way to copy an espressif library to a project to work with it.
Specifically I need to work with the
.platformio/packages/framework-arduinoespressif/libraries/ESP8266WebServer
I copied into my lib/ESP8266WebServer, work with it and I would like to override the espressif library.
The platformio’s lib finder its copying the original one.
thanks in advance,
Sebastián
Hi, Sebastián!
Libraries from lib
folder have a higher priority than ones located in a framework.
I’ve just copied ESP8266WebServer
to local lib
folder in the project and everything works as expected - PlatformIO uses ESP8266WebServer
from lib
folder. Am I missing something from your issue? Have you tried to delete entire .pioenvs
folder?
You are right! I was having an issue changing the folder name.
Thanks
