Hi all,
I’m using the latest version of PlatformIO in vscode on Windows 10.
I tried to run with both arduino and espidf frameworks here in my platformio.ini
[env]
framework = arduino, espidf
lib_deps = adafruit/Adafruit BME680 Library@^2.0.0
platform_packages =
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git
framework-espidf @ https://github.com/espressif/esp-idf.git
[env:featheresp32]
board = featheresp32
As I tried to use framework-arduinoespressif32 @ GitHub - espressif/arduino-esp32: Arduino core for the ESP32 only and getting that error:
Failed to resolve component ‘arduino_tinyusb’.
I tried to override framework-espidf to get the latest components and try to adapt the build, but the repo is checking out into the cache file instead of inside the packages/framework-espidf folder.
How can I avoid the cache folder?
