I have a set-up that run on my notebook (I5, 4 core) fine, a bluepill and stlink. I have 5 nucleo boards, can even debug (single step), all nucleo 64/144 works fine. Downloading never a problem, however, if I use my Ryzen (8 core) some stlinks works sometimes, some never, it seem like the faster CPU have a timing issue. I use Kubuntu. How can I slow OpenOCD within platformIO ?
It is somewhat unlikely that the Ryzen’s higher speed causes a problem. The computer communicates to the STLink via USB 2 and the USB speed does not change.
Can you provide a more detailed error description: What error message do you get? What actions do you execute that lead up to the error?
My ini file looks like this
[env:bluepill_f103c8]
platform = GitHub - platformio/platform-ststm32: ST STM32: development platform for PlatformIO
board = bluepill_f103c8
board_build.core = stm32
;monitor_speed = 115200
;monitor_port = /dev/ttyACM0
-D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
-D USBCON
-D USBD_VID=0x0483
-D USB_MANUFACTURER=“Unknown”
-D USB_PRODUCT=“"BLUEPILL_F103C8"”
-D HAL_PCD_MODULE_ENABLED
-fexceptions
The response I get us : Note I added extra 5th line to connect the stlink reset to the bluepill reset line, this solved a lot of programming isssues
I use Roger generic_boot20_pc13.bin as bootloader.
Processing bluepill_f103c8 (platform: GitHub - platformio/platform-ststm32: ST STM32: development platform for PlatformIO; board: bluepill_f103c8; framework: arduino)
Verbose mode can be enabled via
-v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: ST STM32 6.0.0 #89a8dd7 > BluePill F103C8
HARDWARE: STM32F103C8T6 72MHz, 20KB RAM, 64KB Flash
DEBUG: Current (stlink) External (blackmagic, jlink, stlink)
- framework-arduinoststm32 4.10800.200207 (1.8.0)
- tool-dfuutil 1.9.190708
- tool-openocd 2.1000.190707 (10.0)
- tool-stm32duino 1.0.1
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Found 10 compatible libraries
Scanning dependencies…
Checking size .pio/build/bluepill_f103c8/firmware.elf
RAM: [== ] 19.9% (used 4076 bytes from 20480 bytes)
Flash: [==== ] 44.4% (used 29124 bytes from 65536 bytes)
Configuring upload protocol…
AVAILABLE: blackmagic, dfu, jlink, mbed, stlink
Uploading .pio/build/bluepill_f103c8/firmware.elf
xPack OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev (2019-07-17-11:25)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
debug_level: 1hla_swd
none separateError: timed out while waiting for target halted
embedded:startup.tcl:449: Error: ** Unable to reset target **
in procedure ‘program’
in procedure ‘program_error’ called at file “embedded:startup.tcl”, line 474
at file “embedded:startup.tcl”, line 449
*** [upload] Error 1
=================== [FAILED] Took 2.78 seconds ===================
The terminal process terminated with exit code: 1Terminal will be reused by tasks, press any key to close it.
If I’m not mistaken, the output none separate
means that software reset is used (instead of SRST or TRST). Have you tried without wiring up the reset?
I actually started without the reset, and added reset after I experience the problem, it worked miles better with the reset connected, like said in the original comment. It does works, sometimes. On my notebook I can download 20 times in a row without a problem, on my desktop I have like one in 10 success
Just something that may help: once the program is downloaded, I can single step, place break points etc, no problem. Usually with my experience is that it is just the opposite, easy to download difficult to single step.
