Nucleo F767ZI -cannot flash using serial
Hi ,
I was trying to flash a code using serial bootloader and it gives the following error ,
Unknown/unsupported device (Device ID: 0x451)
I have no issues with flashing on F429zi ,not sure if the PID for serial bootloader on platformio is not matching since the PID for f767zi is 0x451.Also i can flash using st flash loader demonstrator .
.ini is ,
[env:nucleo_f767zi]
platform = ststm32
board = nucleo_f767zi
upload_protocol= serial
upload_port = COM5
Does Platformio explicitly check for the PID before it flash using serial ? if so is there a way to change it ?
Thanks ,
Samson.
The check is done by stm32flash and is 2 minor versions behind (0.4 vs 0.6).
Can you try the following: Download Download stm32flash, copy the stm32flash.exe from there to C:\Users\<user>\.platformio\packages\tool-stm32duino\stm32flash. Does it work now?
Hi Max ,
Yes it works !
Thank you .
