I installed platformIO under vscode on my mac without issue and everything works as it should but the debugger is having a little tantrum:
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : tcl server disabled
Info : telnet server disabled
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Info : STLINK v2 JTAG v29 API v2 SWIM v18 VID 0x0483 PID 0x374B
Info : using stlink api v2
Info : Target voltage: 3.281213
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : device id = 0x10006421
Info : flash size = 65450kbytes
Assertion failed: ((bank->size >> 10) == flash_size_in_kb), function stm32x_probe, file /Users/ilg/Work/openocd/openocd.git/src/flash/nor/stm32f2x.c, line 1074.
.pioinit:10: Error in sourced command file:
Remote connection closed
My board is an STM32F446.
and my platform.ini:
[env:nucleo_f446re]
platform = ststm32
board = nucleo_f446re
framework = mbed
debug_tool = stlink
build_flags = -D PIO_FRAMEWORK_MBED_EVENTS_PRESENT -D PIO_FRAMEWORK_MBED_RTOS_PRESENT -D PIO_FRAMEWORK_MBED_FILESYSTEM_PRESENT
Any idea what’s going on ?
Thanks
