i’m working with adafruit bluefruit board i want to try on the blue led blink sketch.
It was not easy even with arduino ide but doable:
- install the board library
- installed jlink commander for linux x64
- install the nrftool (python code)
sketch compiles and uploads (the regular blink sketch but using LED_BLUE instead of LED_BUILTIN).
with platform io i first tried with the LED_BUILTIN. i could compile of course, but not upload cause the default i jlink. i could see there is nrfjprog package and possibility to upload, but i had to add upload_protocol = nrfjprog
to my platformio.ini file.
Before i had jlink commander installed i got an error that jlink dll is missing (dll ??? on linux ???)
after the installation i get
ERROR: There is no debugger connected to the PC. *** [upload] Error 41
i’m connected using usb cable and i get /dev/ttyUSB defined and also i am able to upload using arduino ide, however arduino ide does NOT use the nrdjprog, at least not directly. it uses nrftools which i didn’t see at all in the platform defs of the nrf52-dk.
I didn’t even try to compile with LED_BLUE.
so
a. does it suppose to work or am i using the wrong upload protocol ? again, using usb cable DFU upload.
b. if it should not is there any expected support in this ? not WIP but something i can actually work with.
updating my own question after looking at Support for the Adafruit Feather nRF52 Bluefruit LE board · Issue #8 · platformio/platform-nordicnrf52 · GitHub seems like i’m not the only one understanding the nrf52-dk platform is not adafruit nrf52.
also i’ve discovered many includes are missing from the compilation commands while the code itself exists in the downloaded core dependencies! a hack of custom compile flags can solve it. but it’s a hack, not a working solution.
