I’ve been using platformio for dozens of esp8266 projects no problem. I got a shiny new esp32s Labelled as NODEMCU-32 aithinker.
I created a new project (NODEMCU-32s was the closest match) and have left setup and loop completely blank for now and hit build. It fails as below.
Fairly fundamental, probably really simple issue. Anyone know if I need to fiddle something else elsewhere?
Processing nodemcu-32s (platform: espressif32; board: nodemcu-32s; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/nodemcu-32s.html
PLATFORM: Espressif 32 1.11.2 > NodeMCU-32S
Found 26 compatible libraries
Linking .pio\build\nodemcu-32s\firmware.elf
c:/users/x/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/lib\libstdc++.a: error adding symbols: File format not recognized
*** [.pio\build\nodemcu-32s\firmware.elf] Error 1
