I am new into the Arduino and Platformio so sorry if I do something in the wrong way… when I try to build the project - no error but build is FAILED, could the log below help resolve my problem? thanks in advance.
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
PLATFORM: Espressif 32 1.11.1 > DOIT ESP32 DEVKIT V1
PACKAGES: toolchain-xtensa32 2.50200.80 (5.2.0), framework-arduinoespressif32 2.10004.191002 (1.0.4), tool-esptoolpy 1.20600.0 (2.6.0)
Found 33 compatible libraries
|-- ArduinoJson> 5.13.3
|-- "ESP32WebServer> 1.0
| |-- "WiFi> 1.0
| |-- "FS> 1.0
|-- "HTTPClient> 1.2
| |-- "WiFi> 1.0
| |-- "WiFiClientSecure> 1.0
| | |-- "WiFi> 1.0
|-- "Preferences> 1.0
|-- "RTClib> 1.3.3
| |-- "Wire> 1.0.1
|-- "UniversalTelegramBot> 1.1.0
| |-- "ArduinoJson> 5.13.3
|-- "WiFi> 1.0
| |-- "WiFi> 1.0
|-- "Wire> 1.0.1
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
src\main.cpp: In function 'void get_cal_value()':
src\main.cpp:187:58: warning: passing NULL to non-pointer argument 3 of 'size_t Preferences::getBytes(const char*, void*, size_t)' [-Wconversion-null]
size_t schLen = eeprom.getBytes("dosTimers", NULL, NULL);
src\main.cpp: In function 'void Task_dosingPomp(void*)':
src\main.cpp:704:138: warning: 'utime' may be used uninitialized in this function [-Wmaybe-uninitialized]
if (dosers_Timers_[pomp].is_off == false && dosers_Timers_[pomp].is_run == false && utime >= dosers_Timers_[pomp].timeStart[i] && utime " dosers_Timers_[pomp].timeStop[i] ) {
Linking .pio\build\esp32doit-devkit-v1\firmware.elf
.pio\build\esp32doit-devkit-v1\src\main.cpp.o:(.literal._Z17handleNewMessagesi+0xa4): undefined reference to `GetTime(int)'
.pio\build\esp32doit-devkit-v1\src\main.cpp.o:(.literal._Z17handleNewMessagesi+0xa8): undefined reference to `RTC_Update()'
.pio\build\esp32doit-devkit-v1\src\main.cpp.o:(.literal._Z5setupv+0x44): undefined reference to `StartTime()'
.pio\build\esp32doit-devkit-v1\src\main.cpp.o: In function `handleNewMessages(int)':
D:\igorlab\Dropbox\Ardunio\!Programs\!Doser\DoserLab_2.1/src/main.cpp:862: undefined reference to `GetTime(int)'
D:\igorlab\Dropbox\Ardunio\!Programs\!Doser\DoserLab_2.1/src/main.cpp:862: undefined reference to `RTC_Update()'
.pio\build\esp32doit-devkit-v1\src\main.cpp.o: In function `setup()':
*** [.pio\build\esp32doit-devkit-v1\firmware.elf] Error 1
========================= [FAILED] Took 23.80 seconds =========================
