I am trying to compile the code below, however I’m getting the following message:
src\main.cpp:568:15: error: no matching function for call to ‘line_chart::draw()’.
I have tried using PlatformIO Corde, version 6.1.3 and Visual Studio Code. I have also tried running it in two different laptops.
main.cpp:
#include "Config.h"
#include "ConfigurationMode.h"
// Storage
#include <ExtFlashLoader.h>
#include "Storage.h"
static ExtFlashLoader::QSPIFlash Flash_;
static Storage Storage_(Flash_);
// Network
#include <Network/WiFiManager.h>
#include <Network/TimeManager.h>
#include <Aziot/AziotDps.h>
#include <Aziot/AziotHub.h>
#include <ArduinoJson.h>
static bool isWifiConfigured = false;
static WiFiManager WifiManager_;
static TimeManager TimeManager_;
static std::string HubHost_;
static std::string DeviceId_;
static AziotHub AziotHub_;
static unsigned long TelemetryInterval_ = TELEMETRY_INTERVAL; // [sec.]
static unsigned long nextTelemetrySendTime = 0;
* @brief Printf function uses vsnprintf and output using Arduino Serial
* @param[in] format Variable argument list
void ei_printf(const char *format, ...)
static char print_buf[200] = {0};
va_list args;
va_start(args, format);
int r = vsnprintf(print_buf, sizeof(print_buf), format, args);
va_end(args);
if (r > 0)
Serial.write(print_buf);
static void ConnectWiFi()
ei_printf("Connecting to SSID: %s\n", Storage_.WiFiSSID.c_str());
WifiManager_.Connect(Storage_.WiFiSSID.c_str(), Storage_.WiFiPassword.c_str());
while (!WifiManager_.IsConnected())
ei_printf(".");
delay(500);
ei_printf("Connected\n");
static void SyncTimeServer()
ei_printf("Synchronize time\n");
while (!TimeManager_.Update())
ei_printf(".");
delay(1000);
ei_printf("Synchronized\n");
static bool DeviceProvisioning()
ei_printf("Device provisioning:\n");
ei_printf(" Id scope = %s\n", Storage_.IdScope.c_str());
ei_printf(" Registration id = %s\n", Storage_.RegistrationId.c_str());
AziotDps aziotDps;
aziotDps.SetMqttPacketSize(MQTT_PACKET_SIZE);
if (aziotDps.RegisterDevice(DPS_GLOBAL_DEVICE_ENDPOINT_HOST, Storage_.IdScope, Storage_.RegistrationId, Storage_.SymmetricKey, MODEL_ID, TimeManager_.GetEpochTime() + TOKEN_LIFESPAN, &HubHost_, &DeviceId_) != 0)
ei_printf("ERROR: RegisterDevice()\n");
return false;
ei_printf("Device provisioned:\n");
ei_printf(" Hub host = %s\n", HubHost_.c_str());
ei_printf(" Device id = %s\n", DeviceId_.c_str());
return true;
static bool AziotIsConnected()
return AziotHub_.IsConnected();
static void AziotDoWork()
if(!isWifiConfigured) return;
static unsigned long connectTime = 0;
static unsigned long forceDisconnectTime;
bool repeat;
do {
repeat = false;
const auto now = TimeManager_.GetEpochTime();
if (!AziotHub_.IsConnected()) {
if (now >= connectTime) {
// Serial.printf("Connecting to Azure IoT Hub...\n");
if (AziotHub_.Connect(HubHost_,
DeviceId_,
MODEL_ID,
now + TOKEN_LIFESPAN) != 0) {
// Serial.printf("ERROR: Try again in 5 seconds\n");
connectTime = TimeManager_.GetEpochTime() + 5;
return;
// Serial.printf("SUCCESS\n");
forceDisconnectTime =
static_cast<unsigned long>(TOKEN_LIFESPAN * RECONNECT_RATE);
AziotHub_.RequestTwinDocument("get_twin");
} else {
if (now >= forceDisconnectTime) {
// Serial.printf("Disconnect\n");
AziotHub_.Disconnect();
connectTime = 0;
repeat = true;
} else {
AziotHub_.DoWork();
} while (repeat);
template <typename T>
static void AziotSendConfirm(const char* requestId, const char* name, T value, int ackCode, int ackVersion)
StaticJsonDocument<JSON_MAX_SIZE> doc;
doc[name]["value"] = value;
doc[name]["ac"] = ackCode;
doc[name]["av"] = ackVersion;
char json[JSON_MAX_SIZE];
serializeJson(doc, json);
AziotHub_.SendTwinPatch(requestId, json);
static bool AziotUpdateWritableProperty(const char* name, T* value, const JsonVariant& desiredVersion, const JsonVariant& desired, const JsonVariant& reported = JsonVariant())
bool ret = false;
JsonVariant desiredValue = desired[name];
JsonVariant reportedProperty = reported[name];
if (!desiredValue.isNull())
*value = desiredValue.as<T>();
ret = true;
if (desiredValue.isNull())
if (reportedProperty.isNull())
AziotSendConfirm<T>("init", name, *value, 200, 1);
else if (reportedProperty.isNull() || desiredVersion.as<int>() != reportedProperty["av"].as<int>())
AziotSendConfirm<T>("update", name, *value, 200, desiredVersion.as<int>());
return ret;
template <size_t desiredCapacity>
static void AziotSendTelemetry(const StaticJsonDocument<desiredCapacity>& jsonDoc, char* componentName)
char json[jsonDoc.capacity()];
serializeJson(jsonDoc, json, sizeof(json));
AziotHub_.SendTelemetry(json, componentName);
#include <AceButton.h>
using namespace ace_button;
#include <CircularBuffer.h>
#include <artificial_nose_inference.h>
#include <Multichannel_Gas_GMXXX.h>
#include <Wire.h>
GAS_GMXXX<TwoWire>* gas = new GAS_GMXXX<TwoWire>();
#include "seeed_line_chart.h"
#include <TFT_eSPI.h>
TFT_eSPI tft;
TFT_eSprite spr = TFT_eSprite(&tft); // main sprite
#define DARK_BACKGROUND 0
#define TEXT_COLOR (DARK_BACKGROUND ? TFT_WHITE : TFT_BLACK)
#define BG_COLOR (DARK_BACKGROUND ? TFT_BLACK : TFT_WHITE)
#include "fonts/roboto_bold_28.h"
#include "images/icon_ambient.h"
#include "images/icon_anomaly.h"
#include "images/icon_coffee.h"
#include "images/icon_no_anomaly.h"
#include "images/icon_whiskey.h"
#include "images/icon_wifi.h"
const unsigned short* ICONS_MAP[] = { icon_ambient, icon_coffee, icon_whiskey };
typedef uint32_t (GAS_GMXXX<TwoWire>::*sensorGetFn)();
typedef struct SENSOR_INFO
char* name;
char* unit;
std::function<uint32_t()> readFn;
uint16_t color;
uint32_t last_val;
} SENSOR_INFO;
SENSOR_INFO sensors[4] = {
{ "NO2", "ppm", std::bind(&GAS_GMXXX<TwoWire>::measure_NO2, gas), TFT_RED, 0 },
{ "CO", "ppm", std::bind(&GAS_GMXXX<TwoWire>::measure_CO, gas), TFT_GREEN, 0 },
{ "C2H5OH", "ppm", std::bind(&GAS_GMXXX<TwoWire>::measure_C2H5OH, gas), TFT_BLUE, 0 },
{ "VOC", "ppm", std::bind(&GAS_GMXXX<TwoWire>::measure_VOC, gas), TFT_PURPLE, 0 }
#define NB_SENSORS 4
char title_text[20] = "";
enum MODE
TRAINING,
INFERENCE
enum MODE mode = TRAINING;
enum SCREEN_MODE
SENSORS,
GRAPH,
INFERENCE_RESULTS
enum SCREEN_MODE screen_mode = GRAPH;
int latest_inference_idx = -1;
float latest_inference_confidence_level = -1.;
#define MAX_CHART_SIZE 50
std::vector<doubles> chart_series = std::vector<doubles>(NB_SENSORS, doubles());
// Allocate a buffer for the values we'll read from the gas sensor
CircularBuffer<float, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE> buffer;
uint64_t next_sampling_tick = micros();
#define INITIAL_FAN_STATE LOW
static int fan_state = INITIAL_FAN_STATE;
static bool debug_nn = false; // Set this to true to see e.g. features generated
// from the raw signal
void draw_chart();
enum class ButtonId
C,
LEFT,
RIGHT,
UP,
DOWN,
PRESS
static const int ButtonNumber = 6;
static AceButton Buttons[ButtonNumber];
static void ReceivedTwinDocument(const char* json, const char* requestId)
if (deserializeJson(doc, json)) return;
if (doc["desired"]["$version"].isNull()) return;
if (AziotUpdateWritableProperty("telemetryInterval", &TelemetryInterval_, doc["desired"]["$version"], doc["desired"], doc["reported"]))
nextTelemetrySendTime = millis() + TelemetryInterval_;
// ei_printf("New telemetryInterval = %d\n", TelemetryInterval_);
static void ReceivedTwinDesiredPatch(const char* json, const char* version)
if (doc["$version"].isNull()) return;
if (AziotUpdateWritableProperty("telemetryInterval", &TelemetryInterval_, doc["$version"], doc.as<JsonVariant>()))
static void ButtonEventHandler(AceButton *button, uint8_t eventType, uint8_t buttonState)
const uint8_t id = button->getId();
if (ButtonNumber <= id)
return;
switch (eventType) {
case AceButton::kEventReleased:
switch (static_cast<ButtonId>(id)) {
case ButtonId::C:
// Toggle Fan
fan_state = (fan_state == HIGH) ? LOW : HIGH ;
digitalWrite(D0, fan_state); // Turn fan ON
break;
case ButtonId::PRESS:
mode = (mode == INFERENCE) ? TRAINING : INFERENCE;
spr.pushSprite(0, 0);
break;
case ButtonId::LEFT:
switch (screen_mode) {
case INFERENCE_RESULTS:
break;
case GRAPH:
screen_mode = SENSORS;
break;
break;
case ButtonId::RIGHT:
case SENSORS:
break;
case GRAPH:
screen_mode = INFERENCE_RESULTS;
break;
break;
break;
static void ButtonInit()
Buttons[static_cast<int>(ButtonId::C)].init(
WIO_KEY_C, HIGH, static_cast<uint8_t>(ButtonId::C));
Buttons[static_cast<int>(ButtonId::LEFT)].init(
WIO_5S_LEFT, HIGH, static_cast<uint8_t>(ButtonId::LEFT));
Buttons[static_cast<int>(ButtonId::RIGHT)].init(
WIO_5S_RIGHT, HIGH, static_cast<uint8_t>(ButtonId::RIGHT));
Buttons[static_cast<int>(ButtonId::UP)].init(
WIO_5S_UP, HIGH, static_cast<uint8_t>(ButtonId::UP));
Buttons[static_cast<int>(ButtonId::DOWN)].init(
WIO_5S_DOWN, HIGH, static_cast<uint8_t>(ButtonId::DOWN));
Buttons[static_cast<int>(ButtonId::PRESS)].init(
WIO_5S_PRESS, HIGH, static_cast<uint8_t>(ButtonId::PRESS));
ButtonConfig* buttonConfig = ButtonConfig::getSystemButtonConfig();
buttonConfig->setEventHandler(ButtonEventHandler);
buttonConfig->setFeature(ButtonConfig::kFeatureClick);
static void ButtonDoWork()
for (int i = 0;
static_cast<size_t>(i) < std::extent<decltype(Buttons)>::value;
++i) {
Buttons[i].check();
void setup()
Storage_.Load();
pinMode(D0, OUTPUT);
pinMode(WIO_KEY_A, INPUT_PULLUP);
pinMode(WIO_KEY_B, INPUT_PULLUP);
pinMode(WIO_KEY_C, INPUT_PULLUP);
pinMode(WIO_5S_UP, INPUT_PULLUP);
pinMode(WIO_5S_DOWN, INPUT_PULLUP);
pinMode(WIO_5S_LEFT, INPUT_PULLUP);
pinMode(WIO_5S_RIGHT, INPUT_PULLUP);
pinMode(WIO_5S_PRESS, INPUT_PULLUP);
if (digitalRead(WIO_KEY_A) == LOW &&
digitalRead(WIO_KEY_B) == LOW &&
digitalRead(WIO_KEY_C) == LOW )
ei_printf("In configuration mode\r\n");
ConfigurationMode(Storage_);
ButtonInit();
digitalWrite(D0, INITIAL_FAN_STATE);
gas->begin(Wire, 0x08); // use the hardware I2C
tft.begin();
tft.setRotation(3);
spr.setColorDepth(8);
spr.createSprite(
tft.width(),
tft.height()); // /!\ this will allocate 320*240*2 = 153.6K of RAM
spr.fillSprite(BG_COLOR);
spr.setTextColor(TEXT_COLOR);
spr.setFreeFont(&FreeSans12pt7b);
if(! Storage_.WiFiSSID.empty()) {
isWifiConfigured = true ;
spr.drawString("Wi-Fi", 20, 40);
spr.pushSprite(0,0);
ConnectWiFi();
spr.drawXBitmap(320 - 24 - 4, 4, icon_wifi, 24, 24, TFT_GREEN, BG_COLOR);
spr.drawString("Wi-Fi ... OK", 20, 40);
spr.drawString("Time sync.", 20, 70);
SyncTimeServer();
spr.drawString("Time sync. ... OK", 20, 70);
spr.drawString("Provisioning", 20, 100);
if (!DeviceProvisioning()) abort();
spr.drawString("Provisioning ... OK", 20, 100);
spr.drawString("Azure IoT Hub", 20, 130);
AziotDoWork();
spr.drawString("Azure IoT Hub ... OK", 20, 130);
AziotHub_.SetMqttPacketSize(MQTT_PACKET_SIZE);
AziotHub_.ReceivedTwinDocumentCallback = ReceivedTwinDocument;
AziotHub_.ReceivedTwinDesiredPatchCallback = ReceivedTwinDesiredPatch;
int fan = 0;
void loop()
if(isWifiConfigured && WifiManager_.IsConnected()) {
ButtonDoWork();
AziotDoWork();
if (mode == TRAINING) {
strcpy(title_text, "Training mode");
if (screen_mode != INFERENCE_RESULTS) {
spr.setFreeFont(&Roboto_Bold_28);
spr.drawString(title_text, 15, 10, 1);
for (int8_t line_index = 0; line_index <= 2; line_index++) {
spr.drawLine(
0, 50 + line_index, tft.width(), 50 + line_index, TEXT_COLOR);
spr.setFreeFont(&FreeSansBoldOblique9pt7b); // Select the font
uint64_t new_sampling_tick = -1;
if (micros() > next_sampling_tick) {
new_sampling_tick = micros() + (EI_CLASSIFIER_INTERVAL_MS * 1000);
next_sampling_tick = new_sampling_tick;
for (int i = NB_SENSORS - 1; i >= 0; i--) {
uint32_t sensorVal = sensors[i].readFn();
if (sensorVal > 999) {
sensorVal = 999;
sensors[i].last_val = sensorVal;
if (chart_series[i].size() == MAX_CHART_SIZE) {
chart_series[i].pop();
chart_series[i].push(sensorVal);
if (new_sampling_tick != -1) {
buffer.unshift(sensorVal);
case SENSORS: {
for (int i = 0; i < NB_SENSORS; i++) {
int x_ref = 60 + (i % 2 * 170);
int y_ref = 100 + (i / 2 * 80);
spr.drawString(sensors[i].name, x_ref - 24, y_ref - 24, 1);
spr.drawRoundRect(x_ref - 24, y_ref, 80, 40, 5, TEXT_COLOR);
spr.drawNumber(chart_series[i].back(), x_ref - 20, y_ref + 10, 1);
spr.setTextColor(TFT_GREEN);
spr.drawString(sensors[i].unit, x_ref + 12, y_ref + 8, 1);
break;
case GRAPH: {
auto content = line_chart(10, 60); //(x,y) where the line graph begins
content.height(tft.height() - 70 * 1.2)
.width(tft.width() - content.x() * 2)
.based_on(0.0)
.show_circle(false)
.value(chart_series)
.x_role_color(TEXT_COLOR)
.y_role_color(TEXT_COLOR)
.x_tick_color(TEXT_COLOR)
.y_tick_color(TEXT_COLOR)
.x_auxi_role(dash_line().color(TFT_DARKGREY))
.color(sensors[0].color, sensors[1].color, sensors[2].color, sensors[3].color)
.draw();
spr.setFreeFont(&FreeSans9pt7b);
spr.setTextColor(sensors[i].color);
spr.setTextDatum(BC_DATUM);
spr.drawString(sensors[i].name, 70 + (i * 70), 236, 1);
spr.setTextDatum(TL_DATUM); // reset to default
break;
case INFERENCE_RESULTS: {
spr.drawString("Outputting sensor data to serial.", 16, 60, 1);
spr.drawString("Use Edge Impulse CLI on your", 16, 100, 1);
spr.drawString("computer to upload training", 16, 120, 1);
spr.drawString("data to your project.", 16, 140, 1);
default: {
break; // nothing
if(millis() >= nextTelemetrySendTime)
if (AziotIsConnected())
doc["no2"] = sensors[0].last_val;
doc["co"] = sensors[1].last_val;
doc["c2h5oh"] = sensors[2].last_val;
doc["voc"] = sensors[3].last_val;
AziotSendTelemetry<JSON_MAX_SIZE>(doc, "gas_sensor");
nextTelemetrySendTime = millis() + TelemetryInterval_ * 1000;
ei_printf("%d,%d,%d,%d\n", sensors[0].last_val, sensors[1].last_val, sensors[2].last_val, sensors[3].last_val);
} else { // INFERENCE
if (!buffer.isFull()) {
ei_printf("Need more samples to start infering.\n");
} else {
// Turn the raw buffer into a signal which we can then classify
float buffer2[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
for (int i = 0; i < buffer.size(); i++) {
buffer2[i] = buffer[i];
ei_printf("%f, ", buffer[i]);
ei_printf("\n");
signal_t signal;
int err = numpy::signal_from_buffer(
buffer2, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
if (err != 0) {
ei_printf("Failed to create signal from buffer (%d)\n", err);
return;
// Run the classifier
ei_impulse_result_t result = { 0 };
err = run_classifier(&signal, &result, debug_nn);
if (err != EI_IMPULSE_OK) {
ei_printf("ERR: Failed to run classifier (%d)\n", err);
return;
// print the predictions
size_t best_prediction = 0;
ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d "
"ms.): \n",
result.timing.dsp,
result.timing.classification,
result.timing.anomaly);
int lineNumber = 60;
char lineBuffer[30] = "";
for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
if (result.classification[ix].value >=
result.classification[best_prediction].value) {
best_prediction = ix;
sprintf(lineBuffer,
" %s: %.5f\n",
result.classification[ix].label,
result.classification[ix].value);
ei_printf(lineBuffer);
if (screen_mode == INFERENCE_RESULTS) {
if (best_prediction != latest_inference_idx) {
// clear icon background
spr.pushImage(30, 35, 130, 130, (uint16_t*)ICONS_MAP[best_prediction]);
spr.setTextDatum(CC_DATUM);
spr.drawString(title_text, 160, 200, 1);
#if EI_CLASSIFIER_HAS_ANOMALY == 1
sprintf(lineBuffer, " anomaly score: %.3f\n", result.anomaly);
if (mode == INFERENCE && screen_mode == INFERENCE_RESULTS) {
spr.pushImage(160,
35,
130,
130,
(result.anomaly > 0.7 || result.anomaly < -0.7) ? icon_anomaly : icon_no_anomaly);
sprintf(title_text,
"%s (%d%%)",
result.classification[best_prediction].label,
(int)(result.classification[best_prediction].value * 100));
ei_printf("Best prediction: %s\n", title_text);
// check if we need to report a change in detected scent to the IoT platform.
// 2 cases: new scent has been detected, or confidence level of a scent previously reported as changed by 5+ percentage points
if(isWifiConfigured && best_prediction != latest_inference_idx ||
best_prediction == latest_inference_idx && (result.classification[best_prediction].value - latest_inference_confidence_level > .05) )
doc["latestInferenceResult"] = title_text;
static int requestId = 444; char b[12];
AziotHub_.SendTwinPatch(itoa(requestId++, b, 10), json);
//ei_printf("Reporting: %s\r\n", title_text);
latest_inference_idx = best_prediction;
latest_inference_confidence_level = result.classification[best_prediction].value;
spr.pushSprite(0, 0, TFT_MAGENTA);
// Uncomment block below to dump hex-encoded TFT sprite to serial **/
uint16_t width = tft.width(), height = tft.height();
// Image data: width * height * 2 bytes
for (int y = 0; y < height ; y++) {
for (int x=0; x<width; x++) {
Serial.printf("%04X", tft.readPixel(x,y));
platformio.ini
[env:seeed_wio_terminal]
platform = atmelsam
board = seeed_wio_terminal
platform_packages =
framework-arduino-samd-seeed@https://github.com/Seeed-Studio/ArduinoCore-samd.git
toolchain-gccarmnoneeabi@~1.90301.0
debug_tool = jlink
;upload_protocol= jlink
upload_port = C:\Users\Carloz-TUF\UF2
-DARDUINO_ARCH_SAMD
-DEIDSP_USE_CMSIS_DSP
-DEIDSP_LOAD_CMSIS_DSP_SOURCES
-DEI_CLASSIFIER_TFLITE_ENABLE_CMSIS_NN
-D__STATIC_FORCEINLINE=__STATIC_INLINE
-std=c++17
-std=gnu++17
-O3
-DAZ_NO_LOGGING
; -DconfigTOTAL_HEAP_SIZE=30720
build_unflags =
-std=gnu++11
https://github.com/Seeed-Studio/Seeed_Multichannel_Gas_Sensor
https://github.com/Seeed-Studio/Seeed_Arduino_Linechart
rlogiacco/CircularBuffer@^1.3.3
https://github.com/bxparks/AceButton
;https://github.com/lovyan03/LovyanGFX#0.3.10
; BEGIN Azure IoT dependencies
https://github.com/SeeedJP/pio-azure-sdk-for-c#1.1.0
https://github.com/Seeed-Studio/Seeed_Arduino_rpcWiFi
https://github.com/Seeed-Studio/Seeed_Arduino_rpcUnified
https://github.com/Seeed-Studio/Seeed_Arduino_mbedtls
https://github.com/Seeed-Studio/Seeed_Arduino_FS
https://github.com/Seeed-Studio/Seeed_Arduino_SFUD
https://github.com/ciniml/ExtFlashLoader
arduino-libraries/NTPClient
knolleary/PubSubClient
hideakitai/MsgPack
bblanchon/ArduinoJson
; END Azure IoT dependencies
