Hello there,
I just wanted to tinker with my Arduino as I have build something.
I always used the Arduino IDE and now I wanted to use VS Code and the PlatformIO extension.
I’ve generated the default Arduino project for Arduino Uno and I’m getting this error and it won’t build.
Unable to resolve configuration with compilerPath "/home/user/.platformio/packages/toolchain-atmelavr/bin/avr-gcc". Using "/etc/profiles/per-user/user/bin/gcc" instead.
When building I get this:
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (5.1.0) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr @ 5.2.0
Found 5 compatible libraries
Compiling .pio/build/uno/src/main.cpp.o
Archiving .pio/build/uno/libFrameworkArduinoVariant.a
Could not start dynamically linked executable: avr-g++
NixOS cannot run dynamically linked executables intended for generic
linux environments out of the box. For more information, see:
https://nix.dev/permalink/stub-ld
Could not start dynamically linked executable: avr-gcc-ar
Compiling .pio/build/uno/FrameworkArduino/CDC.cpp.o
*** [.pio/build/uno/src/main.cpp.o] Error 127
*** [.pio/build/uno/libFrameworkArduinoVariant.a] Error 127
*** [.pio/build/uno/FrameworkArduino/CDC.cpp.o] Error 127
